Prius in desert climates?
Discussion in 'Gen 3 Prius Technical Discussion' started by hlunde, Feb 8, 2012.
  1. hlunde
    hlunde Member
    419
    74
    I'm thinking of giving my 2010 Prius to my daughter in Arizona. Should I be concerned about summer high temperatures and traction battery effects? I've seen posts where there is a concern about blockage of the air inlet to the battery cooling fan. But, what if the ambient air temperature at the inlet is simply very high? Of course AC will be used but for short trips the inlet temperature could exceed 50C. Vehicle has 38,000 miles on odometer.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    It is suppose to take care of itself and will within the operating thresholds. Like the super cold temps up here will probably impact the overall life of the HV batteries, I suspect the high temps will too. How much? I wouldn't worry about it.
  3. ETC(SS)
    6,541
    There are both Toyota dealerships and Priuses in Arizona.
    Don't worry about it.
    If you decide to worry anyway, have your daughter take her (your) G3 into her closest dealership for a looky-see when summer hits, but really......I wouldn't worry about it.
    Joisey is a CARB state, so if the vehicle remains in your name and registered in YOUR state, the battery is covered by the longer warranty period. That's probably not your intent, and it's probably not legal, technically speaking. Yer call.
    OK.....so here's some good news. If your kid reeeeally likes the hybrid thing, and she decides to stay in AZ....they're A CARB state for 2012 and newer vehicles IIRC. Her next car will be thusly covered.
    Good Luck!
  4. hlunde
    hlunde Member
    419
    74
    Good info about warranties. I'm still hoping for some replies from long- term Arizona owners.
  5. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
    I've had the Prius for 2 years now in Phoenix. It does just fine here as the AC will do the job nicely even during 115 degree days. I find it cools down in 3 to 5 minutes, but I suggest your daughter gets a windshield sun deflector if she's parking it all day in an uncovered parking lot. Toyota dealerships have one for about $40 made to size for a Prius.
    Mileage will be lower in the heat of the summer. The HV battery is under more usage to run the AC and hence the ICE is running more to keep it charged. The solar powered sunroof (if yours is equipped) won't do any good in this kind of heat.
  6. hlunde
    hlunde Member
    419
    74
    A quick investigation of battery characteristics tends to alleviate my concerns. See attached graphic.
    Robert Holt likes this.
  7. SDave
    SDave New Member
    Tucson
    I have had a Gen 2 in Tucson for the last 6 years. No problems. The 12v battery even lasted 5 years. None of my other car batteries last more than about 24 months. Mileage will vary with the seasons but I have a lifetime average of over 52 mpg.
  8. PruisAz
    PruisAz Member
    140
    34
    Mesa, Az
    I have not seen any issues with the auto after dealing with our >100F temps. The cabin temp is @78F easily after about two miles of driving. So far my mileage has been @58 - 65mpg with the A/C on. I see Prius autos here in the metropolitan Phoenix area all the time, thousands of them. I'm sure Toyota would of reconsidered sales in this environment if there would of been issues by multiple prius owners. When I went various Toyota dealers to pick out Prius autos, each dealership we went to ad about 20 -30 Prius autos each to keep up with demand. As a previous poster said, standard auto batteries do normally only last two years here in these desert environments.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    All about keeping cabin temp down. Like prev. said must use PriusShop Custom Fit Windowshade (there great!) and car must have dark tint. Crack windows 1/2 inch when sitting too. Then use AC when driving.
    If she lets the cabin cook to death when not using it she will have issues down the road.
  10. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    Never had a problem with my 2004 for the 8 years I had it in Tucson. Don't expect any problems with the 2012 either.
  11. AZGeek
    627
    144
    63
    Arizona
    I religiously use a front windshield solar shade, mainly to keep the dash from taking a beating but also to keep the solar energy heating to a minimum. I never cracked the windows when parked and usually only turned on the A/C when the temps where over 100 F. And my 2004 battery was still going strong after 8 years of operating like this. Not sure I agree that she will have issues down the road if she treats it like a normal car.:)
  12. edthefox5
    10,096
    4,804
    Clearwater, Florida
    You drove around in a car in AZ with temps in the cabin approaching 100 and didn't use the AC?
  13. AZGeek
    627
    144
    63
    Arizona
    ^^ It's a dry heat... ;)
    Grew up in the heat and have never had a problem tolerating a bit more than a normally sane person. :p
  14. vday
    vday Member
    312
    Israel
    AZGeek wrote outdoor temp 100F in the cabin probably closer to 130-140 LOL
  15. Xaran
    Xaran Junior Member
    95
    Im not in Arizona but I live in the high desert area of So Cal, the past 2 -3 months here have been in the 90 -105 temps and my Prius has been the same as any other car Ive owned. Takes 3-5 minutes for the A/C to cool it down, I run my A/C all the time, set at 76. My average MPG running freeways at 65 -85 mph is about 43-46 mpg
  16. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    He probably opened the windows, that would reduce the cabin temperature close to 100F.
    orenji likes this.
  17. AZGeek
    627
    144
    63
    Arizona
    But that messes up the aerodynamics. I prefer to have my body blister from the heat. ;)
    new iPad ?
  18. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Same here. I never use the AC even when it's 110F unless I have passengers.
  19. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Don't you guys sweat and your shirts stick to the seats???
    I have read the Nissan Leaves in AZ are losing battery capacity quicker than elsewhere.
    DailyTech - Nissan Leaf Battery Can't Take Arizona Heat, Dealerships Knocking $5,000 Off Price
    No sure if this is a Li-on thing, or some owners charge it when the car is out in the sun.
    I understand Prii are different because the small % of capacity used, and charging stops once the car is parked.
  20. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    What is the source of this graph?
