Prius in the snow
Discussion in 'Gen 3 Prius Main Forum' started by mtneer79, Oct 24, 2010.
  1. mtneer79
    mtneer79 Junior Member
    Morgantown, WV
    I just bought a 2010 Prius and am starting to become very concerned about driving it in the snow. I'v also heard horror stories about the traction control.What has been everyone's experience?
  2. john1701a
    john1701a Prius Guru
    12,797
    5,279
    57
    With the previous generation, the traction-control was touchy with the factory tires. With better tires, it wasn't a problem for me... 6 winters in Minnesota.
    With the 2010, even with the factory tires it's no big deal. Last year went fine, no concerns for me.
  3. mtneer79
    Morgantown, WV
    Did you purchase snow tires? Is so, which ones do you recommend?
  4. eaglesight333
    eaglesight333 Senior Member
    6,824
    79
    Northern, IL
    The traction control saved my hide a few ties last winter. And this was with OEM tires on my 2010. When it comes time for me to replace my tires, I plan to get a good year round tire.
  5. john1701a
    12,797
    5,279
    57
    Nope, just all-season high-traction did the trick for the 2004... Michelin HydroEdge.
  6. Tideland Prius
    16,445
    The 2010 is a lot better WRT to the traction control system.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Your 2010 Prius is a Gen III. You posted this in the Gen II forum.
    Tom
  8. Tideland Prius
    16,445
  9. Sho-Bud
    Sho-Bud Member
    190
    Amsterdam, Netherlands
    I have a gen II Prius. With the right tires a delight to drive in the snow. Last winter I've seen a lot of cars get stuck or struggling, but the Prius had no probs at all.
  10. donee
    donee New Member
    2,956
    197
    Chicagoland
    A Finish Car Magazine tests cars for winter driving on many aspects each year. The 2010 Prius tied for first last winter. But the comments were its winter fuel economy was so good. But, it did not get knocked out of the running because of traction control issues - which if poor it surely would have been.
    If your not familiar with Finland, its the coldest of the Skandinavian countries.
  11. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
    I'm sure that your Prius handles much better in snow than my BMW Motorcycle did last Saturday morning coming over the Donner Pass in a brief snow storm.
    Keith
  12. AkustaVirtaa
    AkustaVirtaa Sähköistäjä
    198
    Finland EU
    Yep, no problems with Prius in winter. Just remember to switch off ECO mode when driving in deep snow...
    2 people like this.
  13. timo27
    timo27 Member
    316
    52
    Baltimore, MD
    I think ground clearance is the biggest issue--I had no probs last winter as long as there wasn't more than about 4-5" or so on the road. But do keep in mind it is never intended to be some burly SUV.
    Another issue to figure in all this is the cheap-a$$ clips used on the splashguard/oilpan access door. With all that built-in $0.10 plastic integrity, a couple of snowflakes is probably enough to rip them right off.
    :focus:There's a you-tube posted on here somewhere (no time to search for it now) showing the Gen III going up a pretty steep grade on snow atop ice. Slow, but made it. Not a bad traction control at all, imo.
    ~T
  14. qbee42
    18,058
    3,076
    Northern Michigan
    Did you have your chains?
    Tom
  15. patsparks
    10,664
    567
    Adelaide South Australia
    Most BMW motorcycles are shaft drive Tom, don't you know anything? :)
    2 people like this.
  16. dopey423
    dopey423 New Member
    77
    16
    Silicon Valley, CA
    does anyone know how the prius does with stock all seasons and chains on the front? im guessing the same as any other standard car?
  17. qbee42
    18,058
    3,076
    Northern Michigan
    For the 2010, yes. Some of the early Prius have very touchy traction control. That was improved in 2006, but the Gen III 2010s are even better.
    Tom
  18. Jim Clark
    Jim Clark Member
    310
    22
    Northern VA, the 51st state (someday)
    I took our Prius out in a snow storm last winter and put it through its paces in our lightly traveled neighborhood. It was packed snow with some ice. I really pushed it and was quite impressed with how well it did. This was with the OEM Yokohama Avid S33's. I think it might have been better than our Lexus RX400h AWD (pretend AWD...) with the OEM Michelin MXV4's (they suck).
    I wouldn't try deep snow in the Prius, not enough ground clearance.
