Prius inverter pump
Discussion in 'Generation 1 Prius Discussion' started by swordfish, Mar 19, 2021.
  1. swordfish
    swordfish Junior Member
    new york
    i have a 2003 Prius just replace the inverter pump its working but not circulating
  2. Josey
    Josey Active Member
    290
    110
    Virginia
    2003 Prius
    Why did you replace it? You say it's "working." But if it was working, then coolant would circulate. Unless there was a blockage someplace. So maybe you need to say some more stuff about just what exactly you are observing that leads you to believe that it's apparently both working and not working. And what led to the pump replacement in the first place and stuff like that.
