Prius is a midsize sedan, right?
Discussion in 'Gen 2 Prius Main Forum' started by ONwi03, Feb 18, 2006.
  1. ONwi03
    ONwi03 New Member
    40
    I had a discussion with someone who believes it's a compact. It is midsize, correct? Also, could someone provide links that prove either? Thanks.
  2. gschoen
    gschoen Member
    343
    Chicago/Wrigleyville
    2014 Prius Plug-in
    Yes, the 04-06 Prius is a midsize. The earlier Prius I was a compact. www.fueleconomy.gov lists size class of vehicle and interior room.
  3. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    There are two popular ways to classify compact and mid-size (etc.)
    - interior volume: Yes, Prius is a mid-size in this category. Believe it or not, my BMW 540iA is classified as a compact. No kidding. My bimmer has smaller interior volume (cargo space included) than my Prius. This is the way EPA classify vehicles today.
    - wheel-base: No, Prius is considered a compact due to its shorter wheel base. This is the more traditional way how most Americans look at the size of vehicles.
    http://www.fueleconomy.gov/feg/info.shtml#sizeclasses
  4. KTPhil
    KTPhil Active Member
    1,379
    It's a "hybrid"! By that I mean that in terms of interior length, it is midsized. I htink there is less than an inch difference between a Prius and a Camry. Rear seat legroom is awesome for a small car!
    It's width is where it feels more like a compact. Three in the back is just not comfortable.
    Overall, it's a "small midsize" to me--lots of room for stuff and legs, not so much for hips.
  5. Rancid13
    Rancid13 Cool Chick with a Black Prius
    2,452
    Los Alamitos, Orange County, CA
    For comparison's sake, the interior room of the Prius is comparable to that of the Camry, minus about .6 cubic feet I think it is? Based on that, it is considered a mid-sized car. The exterior of the Prius has about the same footprint as the Corolla, making it nimble enough to fit into compact parking spaces that a Camry might not be able to fit into. The turning radius is excellent. :)
  6. ONwi03
    ONwi03 New Member
    40
    Ok, I checked out fueleconomy.gov and it's techinically listed as a midsize. But I do agree that it seems very much like a small midsize.
  7. Walker1
    Walker1 Empire
    911
    FL
    I compared the length of my Honda Accord to the Prius. The Prius is 12" shorter. It's wheelbase is only 1" shorter than Accord. The weight is 600 pounds lighter at 2845 lbs. It seems like the roof is higher and the width is almost identical.
    Consumer re[ports gives high marks to the Prius, but says it's not a mid sized sedan. I think it is a small mid size sedan.
  8. mehrenst
    mehrenst Member
    439
    San Jose, CA
    I think the Prius interior was designed using dimensionally folded space. While its not as wide inside as a Honda Accord the distance between the seatback and the steering wheel is larger and you have a subject feeling that the interior volume is nearer to a full-size car.
    The problem is that if you have an accident the folding of space collapses and you just disappear into some other dimension. :blink: The advantage is there is no mess to clean up. B)
  9. Rancid13
    2,452
    A side-by-side comparison of the 2006 Prius and 2006 Camry SE from Autobytel.com (look at the size differentials):
    2006 Toyota Camry SE Sedan .................2006 Toyota Prius Liftback Hatchback
    General Information
    Estimated Market Price $18,810.14 ........... $21,846.55
    Invoice $18,132.00 ..................................$20,006.00
    List Price $20,375.00 ...............................$21,725.00
    Vehicle Class Midsize ................................Midsize
    Overall Satisfaction Rating 84 out of 100 ....97 out of 100
    Performance
    Engine 2.4L 4 Cylinder ................................ 1.5L 4 Cylinder
    Drive FWD FWD
    Transmission 5 speed Manual OD ................speed Variable Speed Automatic OD
    Compression Ratio 9.60:1........................... 13.00:1
    Horsepower 154 hp @5700rpm ....................110 hp @5000rpm
    Torque 160@ 4000 ......................................82@ 4200
    Bore 3.48 ..................................................2.95
    Stroke 3.78 ...............................................3.33
    Fuel Capacity 18.50 gallons ........................ 11.90 gallons
    Fuel Type Unleaded ................................... Gas/Electric
    Fuel Delivery SEFI ..................................... MPFI
    MPG City 24............................................... 60
    MPG Highway 33 ........................................ 51
    Convenience Features
    Air Conditioning Std ................................... Std
    Power Windows Std ....................................Std
    Power Door Locks Std ................................ Std
    Tilt Steering Wheel - .................................... -
    Cruise Control Std .....................................Std
    Leather Seats N/C ..................................... Opt
    Power Seats Std .......................................... -
    Tachometer Std ...........................................-
    Rear Defroster Std ...................................... Std
    Full Spare - .................................................. -
    Premium Wheels Opt................................... Std
    AM/FM Radio Std ......................................... Std
    Cassette Player - ........................................... -
    CD Player Std .............................................Std
    Sunroof - .....................................................-
    MoonRoof Std -
    Dimensions
    Wheelbase 107.1" ...................................... 106.3"
    Overall Length 189.2" ................................. 175.0"
    Vehicle Height 58.7" .................................... 58.1"
    Vehicle Width 70.7" ..................................... 67.9"
    Seating Capacity 5 ....................................... 5
    Cargo Capacity (Cars) 17 ............................16
    Front Headroom (Cars) 39.2" ....................... 39.1"
    Front Legroom (Cars) 41.6".......................... 41.9"
    Rear Legroom 37.8" ...................................... 38.6"
    Payload Capacity (Trucks) Not Applicable Not Applicable
    Gross Weight (Trucks) Not Applicable Not Applicable
    Towing Capacity (Trucks) 907 Not Applicable
    Final Assembly Location USA J
    Legend
    GRP Not Available for individual purchase RET Manufacturer's Suggested Retail Price
    STD Standard equipment for this model DLR Dealer installed
    PKG Available as part of an option package N/C No Charge
    N/R Status not provided by manufacturer N/A Not Available
    OPT Optional Equipment PIO Port Installed Option
    - Data Not Available * Note applies to this vehicle
    Pardon all the dots. Wanted to sorta line everything up. Here's the link to the website on which the comparison was performed.
  10. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    Overall, it is the 3-inch-narrower and 14-inch-shorter that make people "feel" Prius is a compact when in fact, it is midsize from space perspective. After all, The Prius sit on Corolla chasis and have space as large as Camry.
  11. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    Compared to bloated American scale cars, sure the Prius seems like it should be a “compact†. . . but in comparison to my parent's Ford Taurus, my 6'1†200+ pound body fits better in the Prius. The Prius just feels larger inside. The roof feels higher, the windscreen and dash further away, and it doesn't feel like I am sitting inside of a heavy iron beast.
    Best Car Value Under $23,000 - Toyota Prius
    Best of Midsize Class Under $21,000 – Toyota Prius
    http://www.intellichoice.com/best_values/bovy
  12. Tideland Prius
    16,151
    I don't think the Prius uses the Corolla chassis. It's on its own platform. The Matrix uses the Corolla chassis.
  13. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    thanks Rancid... hmmm the Prius is narrower and shorter but seems to out do the Camry in other areas. i have had 5 people in my Prius several times and all have been very impressed with the legroom. my sister says that when riding in my car, it feels like "we are barely going 30 mph"... so many complain about the harsh ride, but my sister is very impressed. her car... Honda Civic.
  14. Tideland Prius
    16,151
    The Camry feels larger because of its width, yes. Just treat the backseat of the Prius as a two-person limo lol.
  15. icefire
    icefire New Member
    The Prius dwarfs my 05 STI. It's not a small car.
  16. Walker1
    Walker1 Empire
    911
    FL
    The roof is definately higher. I have to stand on a milk crate to wash it. When I wash my Accord I don't need the crate.
