Prius is dead??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dejon, Feb 23, 2018.
Tags:
  1. Dejon
    Dejon New Member
    Arkansas
    About 2 days ago i was heading to school and had my cruise set at 60 while going up hill my car quit accelerating and when pushing the pedal it wouldn't go I got over the hill slowly and pulled over put my car in park and tried to start it again when I did this the car showed tons of lights including the red triangle sadly I had to have it towed home and its currently dead in the drive and just shows the lights when turned on it won't go into drive and the gas engine won't come on.
    51,983
    welcome!
    could be a few things, inverter pump, hybrid battery, hard to know without the trouble codes.
    how many miles on her?
  3. Dejon
    Dejon New Member
    Arkansas
    357,000 and I kinda thought it was the inverter pump but I need to get the codes I just can't get it anywhere at the moment
  4. JC91006
    16,769
    8,567
    When you said, "when pushing hte pedal it wouldn't go I got over the hill slowly". How did you accomplish getting over the hill if it didn't go? Was it going really slowly? How far did you drive to get it over the hill?
  5. terramir
    terramir Member
    318
    51
    Los Angeles
    Hmm agree with bisco, on inverter pump and HV battery but if you can't get the codes, reset the 12v battery and if it starts and last more than two full steps about 10 sec each on the gas in Drive with the other foot on the brake, more than likely inverter pump unless you can hear the darn thing turning (window and hood open you should hear that noisy old pump) (don't drive it even though you could you'll fry your invertor!!!!!!!!) if it doesn't hv battery. 90 % of the time because the inverter over heating if you clear the code will let the car start and the inverter will take more than 20 sec to heat up, but an inbalanced HV battery will usually throw a code asap. even after reset if you try to force charge it with two or three pulses.
    my $.02
    terramir
  6. Dejon
    Dejon New Member
    Arkansas
    I was doing 60 about 3/4s the way it quit so I was doing around 35 when I peaked the hill coasted about 100 feet to a shoulder and parked it
  7. terramir
    terramir Member
    318
    51
    Los Angeles
    357k hmmm have you had your hv battery rebuilt/replaced and when?
  8. Dejon
    Dejon New Member
    Arkansas
    I have not had it rebuilt or replaced how would I test it if it needs to be because replacing the battery is more than the cars worth I am the second owner and it seems to be completely original
  9. JC91006
    16,769
    8,567
    If your inverter pump shorted out, it would blow the AM2 fuse inside your engine compartment fuse box. Check that fuse and see if it's blown.
  10. terramir
    terramir Member
    318
    51
    Los Angeles
    sometimes that pump just quits without a short BTW. happened to me. but 357k on original battery way to go, my battery quit around 160k-170k miles had to keep rebuilding ever since (now at a true 203-208k miles) and after rebuilding it twice I'm installing a charging port just need to design and 3d print print a darwin proof HV cover to prevent peeps from getting the darwin award. Cause the way it's running now if I dun start charging it monthly it's gonna fail sooner rather than later. 357k on the original battery sounds like a record to me.
  11. Dejon
    Dejon New Member
    Arkansas
    I just checked the AM2 fuse and it's fine
  12. JC91006
    16,769
    8,567
    If that pump just quits, it wouldn't do anything except light up a big Red Triangle when it gets hot. It doesn't disable your car right away.
    The way the OP described how the car died, the pump would have to be shorted out. A bad HV battery wouldn't do that either.
    So if the pump shorted out, then that's what he has to change. If the pump didn't short out, then he would have to do some diagnostics to figure out why the car quit (ex out of gas, inverter failure, failed fuel pump)
  13. Dejon
    Dejon New Member
    Arkansas
    So do you think replacing some modules will help?
  14. JC91006
    16,769
    8,567
    A battery problem would get you into limp mode and still work. Won't disable your car
  15. Dejon
    Dejon New Member
    Arkansas
    The only thing I can rule out for certain is that I didn't run out of gas u was at about 3/4s full
  16. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
  17. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Just buy a Prolong charging lead and the Prolong charger system. Dont have to 3d anything.
    A high mileage battery will require a full discharge/recharge cycle or 2. One discharge woke my 125,000 mile battery right up like new for a year now. Lots of us on this site use the system. Its available in the Prius Shop.
  18. JC91006
    16,769
    8,567
    You would need to get the codes read, the guessing thing can be very time consuming and not very productive in solving your problem.
    The way it just died.....I can tell you it will most likely be a very expensive problem (since it's not the shorted inverter pump)
    exstudent likes this.
  19. Dejon
    Dejon New Member
    Arkansas
    Is there a certain computer that's needed?
  20. JC91006
    16,769
    8,567
    We like using the MiniVci with Techstream using a laptop, but there are apps that can do that now. I don't use the wireless app version so others with more expertise would have to ring in to offer that advice.
