Prius jet noise at highway speeds?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by prio2005, Jan 20, 2011.
  1. prio2005
    prio2005 New Member
    Home
    Bought a 2005 Prius with a perfect history and that recently had its 60k check up at the Toyota dealer. Don't know exactly when the sound changed since I'm not the primary driver, but now it sounds like a jet airplane when it reaches highway speeds and it's hard to hear what we're saying to each other, much less what people are saying over the Bluetooth (although the built in Bluetooth noise cancelation feature is fantastic and the person on the other end of the phone doesn't hear the noisy engine). Any idea what could be causing the car to sound like we're taking off at the airport (at any speeds above 40 mph, it seems)? Our passengers comment on the near constant background noise level.
  2. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    "home' seems vague, but if you are in the mountains, the Prius can use the Engine as a brake when the HV Battery is too full to accept any more power. Were you in a long downhill?
    49,695
    it's the afterburners, you can turn them off with the traction control.
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Were you in D for Drive and not B for engine Brake?
  5. bisco
    49,695
    was it windy out when you heard the noise?
  6. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Check the side mirrors. There are screws on the bottom that should be covered with small caps. If the caps are missing you will hear a whistling noise at highway speeds. Just put some tape over the screw holes and the noise will disappear.
  7. Patrick Wong
    18,200
    6,479
    Is it possible that your car has a bad wheel bearing? It sounds like this problem is easily demonstrated, so I suggest you take the car in for service soon.
  8. KTPhil
    KTPhil Active Member
    1,379
    X2
    Common problem, cheap fix.
  9. bstephens
    bstephens Junior Member
    36
    Oklahoma
    I agree with Patrick. Is the noise more on one side of the car over the other? If so I am willing to bet it is a bad bearing.
  10. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    Poor wheel alignment can sometimes sound like a bad bearing, and if the tire(s) has cupped or otherwise become worn, it can get noisy in a hurry, especially if it is a front tire.
  11. bisco
    49,695
    could be a bad tire?
