PRIUS KEY POPPED OUT OF SLOT !!
Discussion in 'Gen 2 Prius Main Forum' started by Cattaraugus, Feb 9, 2007.
  1. Cattaraugus
    Cattaraugus New Member
    A strange thing happened with my 2006 Prius - It's a SUPER cold morning...about 1 degree outside...I jump in the car, put the key in, push the button, and turn the heater full blast - I go inside for about 15 minutes, come outside, open the door, and the Prius key is sitting on the driver's seat....but the car was still on....
    What happened?? Is this normal?? Has this happened to anyone else?? I took the key, push it back in the slot, and it locked into place...
    All I can think is that I didn't push the key all the way for it to lock into place...and then it just happened to pop out from the spring that is build into the ignition slot.
    Any ideas out there??
  2. SomervillePrius
    SomervillePrius New Member
    944
    Somerville, MA
    Never heard of this before, but it makes sense that the car would still be running as it can run, once started, without a key until powered down.
    And by the way, there is no reason to warm-up the engine for !5 minutes. It's a waste of a precious resource (gas) and bad for the environment. The Prius has a thermos what will pump warm fluids into the engine on start so it really only needs a few seconds.
  3. Stev0
    7,201
    1,073
    Northampton, MA
    2022 Prius Prime
    People actually put the fob in the slot to start the car? Where's the fun in that?
  4. brjacobso
    brjacobso Junior Member
    17
    San Diego
    <div class='quotetop'>QUOTE(Stev0 @ Feb 9 2007, 08:27 AM) [snapback]387490[/snapback]</div>
    exactly! I pride myself in not having to take the "key" out of my pocket. I complain when I have to take out my key to open the front door to my house.
  5. SomervillePrius
    944
    Somerville, MA
    If you look at his profile it states he has a #1....
  6. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    <div class='quotetop'>QUOTE(SomervillePrius @ Feb 9 2007, 10:45 AM) [snapback]387447[/snapback]</div>
    Where is this warm fluid coming from and how did it get warm? :mellow:
  7. Cattaraugus
    yeah, you guys are spoiled...I don't have the fancy keyless Prius.
  8. naterprius
    naterprius Senior Member
    1,843
    <div class='quotetop'>QUOTE(grasshopper @ Feb 9 2007, 10:42 AM) [snapback]387539[/snapback]</div>
    There is a thermos which stores hot coolant up to five days. It is pumped out of the engine when you shut down and pumped back in before startup.
    However, I still need to warm up my car in order to defog/ defrost/ deice etc on bad days.
    Nate
  9. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    Did you keep the doors unlocked?
    Frankly, if my neighbor kept his Prius running and unlocked with the key in the ignition, I'd mess with his head a little.
    I had a friend move my car around the corner while I was delivering pizzas once.
  10. Warwind
    Warwind New Member
    137
    Hedgesville, WV
    Your Prius is obviously suffering from premature ejection...
  11. Cattaraugus
    It may need some therapy...or something...maybe it was just way too excited to run down the road??
  12. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    I only do that when I take it to a lube place and don't want to confuse them.
    Dave M.
