Prius Keys
Discussion in 'Gen 2 Prius Main Forum' started by Mainframe, Nov 28, 2005.
  1. Mainframe
    Mainframe New Member
    Sydney, Australia
    Hi all, just wondering what the prius keys actually looks like.
    isnt it like a smart card that you slide into a slot?
    and are the remote central locking buttons located on it or are they on a sepperate keyfob?
    could somone post a pic of the key?
    :) thanks
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Take a look at <a href=\'http://priuschat.com/index.php?showuser=2156\' target=\'_blank\'>Sufferin' Prius Envy's</a> avatar. The fob (the key is a little metal one in the side of the plastic fob) inserts into a slot in the dash, or if you have the SKS option (available in Australia?) stays in your pocket. There are Lock, Unlock, and Panic buttons on the fob. Sufferin's avatar shows the back of an SKS fob.
    Do a search for fob.
  3. Mainframe
    Sydney, Australia
    yeah we have the keyless starting option as an 'i-pack' but its 8k more :\
    and thanks, ill do a search :)
  4. kente777
    kente777 New Member
    194
    NW Florida
    What happens when the battery in the FOB dies? I know the metal key will open the door, but how do you start the car without the FOB?
    Ken
  5. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    When the battery dies you simply insert the FOB in the slot like on a non-SKS model. Of course most SKS owners probably don't even know the slot exists... :lol:
  6. cooljw
    cooljw Member
    183
    46
    Does the keyless-entry Prius also come with a standard, non-battery operated key? I didn't think it did - I've only seen a black button on the door handles.
    I live in San Diego and when I go surfing, I tuck my car key into a pouch in my wetsuit. Obviously I can't do this with any electronic keys (unless it's really waterproof)!
  7. aaf709
    3,862
    2022 Prius Prime
    Well, a fellow San Diegan! :)
    Yes, the ring on the fob is attached to the key itself. Next to it (along the top) is a little lever. Slide that and the key comes out.
  8. engunneer
    engunneer Member
    307
    Medford, MA
    2020 Prius Prime
    No. For you, you can take the metal door key out of the fob and take that with you, while locking your fob in the car (Turn SKS off or remove the battery from the fob). You may also be able to get a little plastic can with a o-ring seal to hang around your neck or something.
    Mainframe, I seem to remember that you don't get all the same options in Oz that we do here. our '05 model has 6 packages, and you get the keyless entry on about 3 of them. Perhaps there is a lesser package there that still has SKS.
    You can tell an SKS fob from a non-SKS by looking at the color of the toyota logo. Black is non-SKS and Silver (Chrome) is SKS.
    When the battery on a fob dies (either type) it can get enough energy to start the car from the key slot, as stated earlier. As long as the key isn't withing 10 feet of the car at all times, you can expect 5-8 years of life from the battery. The battery is replacable - CR2032, which is a very common size.
  9. cooljw
    cooljw Member
    183
    46
    Thanks for all the info guys. Is it hard to disable the SKS on the Prius? I don't want to have to take the battery out of the fob if I have to leave it in the car.
    I did try wearing a key around my neck once while surfing and I nearly lost it! So I'll never be trying that again.
    Also, good to know that I'll have no problem fitting my longboard in the Prius!
    (credit to John on the Edmunds forum)
    That wood inside the Prius is 10 FEET long!
  10. Brian K
    Brian K New Member
    152
    The key that is part of the e-key is a tiny thing. You can go to Toyota and get a real key made and leave the "emergency" key for just that.
    cooljw, disabling the SKS is a piece of cake. Just reach down and switch it off.
  11. aaf709
    3,862
    2022 Prius Prime
    That is, the button is right under the steering wheel.
  12. Mainframe
    Sydney, Australia
    i could only find one small image of them, and that avatar.
    could somone post some closeup pics of both sides of the key?
    sorry, but i have a wierd obsession with cool car keys :D
  13. XLR8
    XLR8 New Member
    161
    Las Cruces, NM
    :eek:
  14. daniel
    14,487
    1,518
    Spokane, WA
    YOU DO NOT NEED TO TAKE THE BATTERY OUT OF THE FOB!
    Remove the metal key from the fob, leave the fob in the car, and lock the door using the metal key. (There's a regular key slot in the handle of the driver's-side door.) The car will be locked, and you then get back in with the metal key.
    The confusion arises because you cannot lock the door using the Smart Lock button while the fob is inside the car. But you CAN lock it with the metal key.
  15. MyPria
    MyPria New Member
    70
    Colorful Colorado
    Thanks for the info Wayne. I didn't have a clue that the FOB could be inserted into a slot. Daaaaaa
  16. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    Yea, here are the instructions, in case you need to print them for future reference... :lol:
    [Broken External Image]:http://img455.imageshack.us/img455/2391/priuskeyslot4fy.jpg
  17. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Or take your spare fob wrap it in heavy duty aluminum foil and leave it in the car!
  18. Mainframe
    Sydney, Australia
    isnt that alittle unsafe with the key part attaching to your keychain and the actual fob just being attached to a removable bit?
    i would have thought it would be the actual fob that has the little hole in it to attach to a keyring....hmm unless it clicks in really firmly
  19. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    You can barely see it in this picture, but it actually has a spring-loaded slide lock on the end that keeps the emergency key from pulling out:
    [Broken External Image]:http://img455.imageshack.us/img455/2668/lgpriuskeylg4ck.jpg
  20. Mainframe
    Sydney, Australia
    oooh ok, cool :D
