Prius Killer
Discussion in 'Newbie Forum' started by fl8216, Jan 27, 2012.
  1. fl8216
    fl8216 Junior Member
    pensacola
    I work part-time as a News Paper Courter. I'm looking to replace my current car with something more fuel efficient (around 16 mpg). The Prius gets great mpg (45-48), if put the Prius on the route the fuel efficienly will go down (maybe 35 mpg). Will the route of stop, go, turn left, turn right, go, stop, be too hard on the Prius system?
    Tommy
  2. fulltank
    fulltank New Member
    230
    38
    Arkansas
    If it's a morning route where you're in a neighborhood without anyone behind you than you may be able to substitute stop/go for gentle gliding. Even with stop/go you just need to be cautious on how heavy you are with gas pedal. Bottom line, it will do better than whatever you're using now.
  3. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Short Answer - no it will not be too hard on the Prius. There are many Prius taxi cabs and the owners seem to give the Prius high marks for its reliability compared to other, traditional taxi cabs.
    How long is your route? You might even consider a Chevy Volt or a Nissan Leaf, as you could run all electric. If you use the car for other purposes, you'll just need to figure out if the car will suit those applications as well.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    I'm still stuck on your job as a News Paper Courter. A courter is someone who courts or plays the lover, solicits in marriage, or flatters and cajoles. A Prius is pretty pedestrian for that sort of task. I would suggest something with more panache, such as a Lamborghini or Ferrari.
    Tom
  5. fl8216
    pensacola
    Sorry, slip of the finger,
  6. fl8216
    pensacola
    About 25 miles long, and 30 miles to day job and home, (55 miles round trip).
  7. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    LoL :D
  8. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    Newspapers are trying all kinds of incentives to boost circulation.
  9. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Ah, if PEVs were cheaper I'd definitely say PEV!
    It hurts mileage if you have to work the car hard when the engine's still cold. However, you're in FL and you have a normal commute home, I presume, so you'll have a shorter warm-up than somebody in a colder city and you'll have good mileage on your way home.
    The combination of some tough stop and go miles plus those additional miles after your route help the case for getting a prius. Mail carriers and cabbies love their Priuses for the good mileage and you will too. :rockon:
  10. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    You will wish you'd got one years ago. It will save you $hundreds a year in fuel savings.
    The Prius will be at home in the use you've suggested. The engine will be off at low speed most of the time, the batteries will charge as you go down hill or slowly and the engine comes on when faster acceleration is required. The benefit of the Prius is that the a/c will still work off the big batteries without the engine running.
    Seriously, you will wish you'd got a Prius years ago.
  11. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    I've wondered about this WRT the HV battery. If it is like the paper route I had when I was a kid (do they still print newspapers BTW?) it is like stop and go traffic, so the battery will spend most of the time at the minimum charge level, with the ICE running just long enough to bring it up to 50%, then the ICE will shut off until it drops to 40%, then rinse and repeat. What does this do for the long term health of the battery?
  12. hill
    8,253
    I was stumped on that one actually.
    :blush:
  13. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,999
    Fort Lee, NJ
  14. fl8216
    pensacola
    Thanks for all the info., we got a "10" Saturday. Getting 40mpg on the paper route, about 44mpg around town. Learning how to drive to get the better mpg. Love the car! Again thank you all!
    tommy
    2 people like this.
