Prius LED Help
Discussion in 'Gen 2 Prius Accessories & Modifications' started by 2007-Prius-hybrid, Sep 4, 2010.
  1. 2007-Prius-hybrid
    2007-Prius-hybrid New Member
    132
    NY
    Hello-
    I am looking to replace all my interior incandescents with LEDS, Door, Map, dome, and rear cargo light.. does anyone know a good (cheap, lol) place to get these? (white)
    thanks!!
  2. blueumbrella
    blueumbrella Member of Prius Regeneration
    294
    34
    Seattle
    Do a search for LED bulbs. There are a number of good threads with with good references.
  3. cproaudio
    cproaudio Speedlock Overrider
    2,401
    759
    CA
    Ebay is probably the best place to buy LED dome lights. How bright do you want to go? Are you just looking for replacements? or do you want to go all out and really light up your interior? You can check out my interior light mod. It looks like the GenII and GenIII use the same bulbs.
    visor and door
    2x 4 SMD 5050 Side Shine T10 LED lights 2825 W5W White: eBay Motors (item 260592985215 end time Sep-23-10 21:03:11 PDT)
    front maplights
    2x 3W White T10 194 4 SMD High Power LED Wedge Bulbs : eBay Motors (item 220651210012 end time Sep-08-10 02:00:26 PDT)
    Rear dome light
    http://cgi.ebay.com/ebaymotors/Whit...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
    Hatch light
    White 1.25" 32mm 1W High Power DE3022 LED Dome Bulbs: eBay Motors (item 220618872134 end time Sep-06-10 08:06:12 PDT)
  4. 2007-Prius-hybrid
    132
    NY
    HI1 thanks... Do you know if the one for the front dome is the same as the rear dome light?
  5. 2007-Prius-hybrid
    132
    NY
    duh.. nevermind
  6. cproaudio
    2,401
    759
    CA
    according to Lights Replacement Guide your 07 use the same lights as my 10. For the front lights it's listed as 168. If it's the same layout as mine then you'd want a bulb that shines straight forward. That's why I recommend this bulb. The door and the visor bulbs are also 168 but it only shines to one side. That's why I recommend this bulb As for the rear dome, the bulb is recessed into the dome light assembly. Thats why I recommend this bulb. The hatch bulb has some play room so you could use these type of bulb or these.
    If you could buy 25 of these and solder them together and fill all of your light's clear covers and really light up your interior.
  7. krg03
    krg03 Not expert, just experienced
    246
    31
    so cal
    I used these for ALL the interior lights. Some you have to work into place. Comes with all types of adapters. Extremely bright.
    Email the seller also. $2 shipping each item is not good, they knock a bunch off if you order more than one for shipping. Dome, doors, rear, visor.
    http://www.amazon.com/gp/product/B002TY21XY/ref=oss_product
  8. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
  9. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
  10. 2007-Prius-hybrid
    132
    NY
  11. zion
    zion New Member
    VA
    I also just replaced my rear tail lights with the LED 194 bulb from Advanced Autoparts and they work great. Not sure if I got the best deal but they were about $10 for the pair. They are a single LED that just plugs right in the same houseing...
  12. cameljok
    cameljok New Member
    Arizona
    Put pics up after you are done... Great idea..
