Prius Lights
Discussion in 'Prime Main Forum (2017-2022)' started by ukr2, Mar 11, 2017.
  1. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    I can't find what the vertical LED headlights are and how to turn them on. The Manual doesn't identify them.
  2. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    They come on with your headlights come on. The top half of them are your turn signal lights.
    #1 in Easley,SC
    HPrimeAdvanced likes this.
  3. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    My headlights are the Horizontal bulbs. The Vertical LEDs are off and I don't know their purpose.
  4. dalcon95
    512
    653
    Do you have the Prius Prime Plus or Premium? When you turn your headlights on and turn your Hazzard lights on, what do you see come on for your vertical LED lights? On my Advanced, which is pictured, shows what comes on with my headlights and fog lights are on. The top vertical LED lights are turn signal or Hazzard lights.
    #1 in Easley,SC
    #4 dalcon95, Mar 11, 2017
    Montgomery likes this.
  5. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    Dalcon95,
    Why are you driving on your side ???
    I have a Premium, therefore, I don't think I have Fog Lights.
    OK, I'll recheck my Turn Signals and Hazzard lights.
    Where you're showing 3 vertical LEDs on, how do you get the other Vertical LEDs on?
    dalcon95 likes this.
  6. dalcon95
    512
    653
    The other vertical lights are turn signal/Hazzard lights. I decided to save on my tire wear by going sideways. Lol. Actually for some reason the picture loaded that way even though the picture was taken and is saved on my phone correctly.
    #1 in Easley,SC
    Insirt likes this.
  7. Tideland Prius
    16,128
    The 3 white LEDs at the bottom are the "clearance lights" and are only available on the Advanced model.
    The rest of the vertical lights are your turn signals as dalcon has said before. Just turn on your hazard lights and get out of the car, you'll see them.
    @dalcon, couldn't you rotate them inside the photo album of your phone? I know my phone does that some times if it doesn't detect that I rotated my phone. I just manually rotate the photo from the album.
  8. dalcon95
    512
    653
    The photo was displaced on my phone correctly and I have posted it on here before correctly, but for reason it loaded it this way this time. Lol
    #1 in Easley,SC
    Tideland Prius likes this.
  9. DavidA
    2,328
    1,812
    Chicago western burbs
    Just say your Prius Prime is so powerful that you were in a heavy banked turn. We'll all understand, and smile, at your awesome accomplishment.
  10. huskers
    huskers Senior Member
    2,543
    2,486
    Nebraska
    I think he gets better mileage driving on his side. Less wear on at least 2 tires as well.
    CatsAreGods and dalcon95 like this.
  11. dalcon95
    512
    653
    It's all about technique! You should try it! Lol.
    #1 in Easley,SC
  12. Mendel Leisk
    38,653
    Picture rotation can be a real can-o-worms. Since upgrading to Win 10, transferring pics from my iPhone has become real "interesting". I've sort-of cobbled a fix, for pictures at least. For videos: I just resolve to take video landscape only, with the phone's volume buttons oriented towards the ground.
    With Win 10, the only way I can reliably get images oriented correctly: import them with all windows "correct orientation" options OFF. Install a freeware image rotation program, then right-click a folder with images and apply it. Option to fix a folder and folder with it's sub-folders are offered, but only the single folder option actually works, lol.
    Info:
    JPEG AutoRotate
    to fix rotation of jpeg's downloaded from iphones
    JPEG Autorotate - software - Olli Savolainen
    Also, if you're posting on a Windows system, Win7 or higher: look into the (built-in) Snipping Tool. Very handy for screen grabs, and what you see is what you get. Whatever's captured in Snipping Tool is automatically in Cipboard, and pasting while in the Priuschat "more options" editor will always insert the clipboard image.
    I've attached a rotated image, if you want to patch up the rotated posting. Or not, if it'll increase tire wear, lol.
    #12 Mendel Leisk, Mar 12, 2017
    dubj1313, Tideland Prius and dalcon95 like this.
  13. huskers
    2,543
    2,486
    Nebraska
    You should call it, "Pulse and Glide and Oh s**t".
  14. Tideland Prius
    16,128
    dalcon95 and huskers like this.
  15. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    Tideland, There is room for 9 LEDs vertically.
    I couldn't get the top 2 to light. The next 4 are the Turn Signal/Hazzard. And I couldn't get the bottom 3 to light.
    Since I have the Premium without the Fog Lights, that explains the bottom 3.
    What about the top 2?
  16. dalcon95
    512
    653
    It could be a situation where not all the lights are used on all the trims, but they're there just to make the trims uniform for the ease of manufacturing. Sort of like the concept of buttons on the dash for Advanced trim, but a black cover in the same spot on the plus trim, instead of making a whole new dash panel without a hole for a button. Just an idea.
    #1 in Easley,SC
  17. Tideland Prius
    16,128
    I see what you mean. I believe they're blanks (like the row of dots on the 2006-2009 Prius)
  18. DavidA
    2,328
    1,812
    Maybe the last two light up in a different spectrum? IR maybe? ;)
    CatsAreGods, Sandollars and dalcon95 like this.
  19. CharlesH
    2,785
    1,152
    Roseville, CA
    Or the blank in the charging port for high speed DC charging, that is only available in Japan. :(
  20. Insirt
    Insirt Junior Member
    50
    60
    South Carolina
    We need someone to figure out a modification to add the accent lights in the bottom 3 empty slots on a Plus or Premium trim.
    Maybe the top two empty positions too? I feel like that might look odd so other mod option would be to add LEDs in all the spots including the turn signal (share the space, if possible) and turn off the accent lights on that side when using the turn signal as some cars do.
