Prius limps on slight hills, does not respond to accelerator
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BigRic, Dec 11, 2018.
  1. BigRic
    BigRic New Member
    Northern NJ
    We have an 05 Prius that has an odd problem. I noticed it last winter once or twice but now it's happening to my daughter all of the time. When getting onto a slight incline, the car will limp along and not respond to accelerator input. It's almost like it just idles along and then will eventually start working again. The car is throwing codes for the catalytic converter (it needs to be replaced) and the O2 sensor (related to #1). I don't think the cat is blocked, just old (I may be wrong). It's also throwing a MAF error and last year when this started, I replaced the MAF sensor (it happened coming home from an oil-change place and I thought perhaps they overfilled it). It seems to happen mostly when it's very cold out. I have no problem putting a new cat on it, but with 270k miles, I don't know if I'm throwing good money after bad. Any thoughts or suggestions?
    49,704
    welcome!
    there is no way to determine what repairs you might need down the road. have you replaced the hybrid battery yet?
    one rule of thumb is not to spend more than the car is worth, but it is just a guide
    scona likes this.
  3. BigRic
    BigRic New Member
    Northern NJ
    Thanks for the response. I replaced the hybrid battery in August. I've read a lot about folks getting a MAF sensor error even by simply opening the air box, which my daughter did by mistake trying to find the fuse box one night last week. Oddly, the first time it happened after the oil change, the tech had also opened the air box to inspect the filter. After I replaced the sensor that didn't occur again until now. I know the CAT is shot and the O2 sensor has been shimmed a couple of times to compensate and prevent codes, but I'll just have to tackle that problem at this point. Just worried that this might be indicative of something else and that despite being in surprisingly good shape, I'd be wasting money. It amazes me how this car has otherwise held up.
  4. BigRic
    BigRic New Member
    Northern NJ
    One other thing I was worried about was a recent recall notice I saw about some type of water pump wiring short causing the car to stall. That's essentially what happens. You basically have to coast to the side of the road. If you pump the accelerator, nothing happens but then suddenly, it will return to normal.
  5. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
    1) What are you using to read the codes? If you are not using Techstream software, there may be codes your reader can't read.
    2) If you replaced the HV battery with a used/reconditioned/rebuilt/remanufactured/, it won't last long.
    3)
    NO. Overfilled crankcase, dirty MAF, MAF that is dead, MAF wire harness damage, not using MAF cleaner, using too much MAF cleaner, can/will cause problems.
    4)
    The Inverter Pump. When this pump stops working, the Inverter will begin to overheat. The car will begin to shut components off to try and keep the Inverter from overheating. If the AC is on w/ a broken inverter pump, the car will deactivate the AC to save itself. You should also see warning lights on the dash and MFD.
    I am only aware of one person experiencing a catastrophic inverter pump failure. A couple main fuses blew, that essentially killed all electronics, no lights, no hazards, no nothing. It was as if the car did not have any batteries (12V and HV).
    5) Given all the manipulation to the emission equipment, this may be the root cause of the lack of power.
  6. BigRic
    BigRic New Member
    Northern NJ
    Just an update on this. Took the car out this weekend for a test drive to see if my daughter's description was accurate. Seems that the gas engine was actually shutting down (I was able to force this condition by accelerating really hard - it coughed a couple of times then threw the red triangle of death). My daughter did not get the triangle but I think I was just pushing it harder. Ends up the "limping" was falling back to the electric motor alone, causing the low speed and lack of throttle response. I ended up calling a friend who used to be a Toyota mechanic. He suggested cleaning the MAF sensor again or replacing it with an OEM one. I did the latter and interestingly, the new one looks a lot different. The old has a cup-style sensor which seems to pull air down through the cup and out two small side vents. The new one is just an open circle through which air passes (as far as I can tell). The MAF code cleared after cycling the engine 3 or 4 times. Drove it about 60 miles since then and so far, the issue has not occurred. Fingers crossed! Still going to replace the CAT and O2 sensor so it'll pass inspection in May, but hopeful that this was the root cause of this issue.
  7. bisco
    49,704
    congrats, all the best!(y)
