Prius loses power while driving.
Discussion in 'Gen 2 Prius Main Forum' started by ChristieM, Sep 12, 2018.
  1. ChristieM
    ChristieM New Member
    Santa Maria
    2007 prius loses power. Red triangle, ((!)) And VSC lights are displayed. I pull over, turn car off, wait about 10 minutes, turn car back on, drives fine with red triangle only light on. Park at my house overnight. In the morning....no lights car drives fine. Happens about twice a week. Cannot keep losing power! Too dangerous. What can be causing this?Mechanic says he cannot diagnosis problem without lights being on, so by the time I get it to him the lights are off.
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    "Your mechanic" doesn't have to correct tools then. A copy of Techstream would be the official way of doing it, but a $10 bluetooth adapter and a phone work just as well. You need to read the codes. When the lights go off, the codes are stored historically.
    Most probable causes for lack of power that fixes itself is inverter overheating. This problem is commonly caused by a failed or blocked or empty inverter coolant pump. It could be anything and without codes it's all guessing. But that's where I would start.
    Open the hood with the car in READY and check for fluid movement in the inverter coolant reservoir.
    JC91006 likes this.
  3. JC91006
    16,487
    8,402
    You probably have a failed inverter pump. That's been a common failure on these cars after 100k miles
  4. GinaCastano
    GinaCastano New Member
    My prius does the exact same thing. Have taken it to 5 mechanics and none have been able to help me. Just as I am ready to give up and buy another vehicle, the red triangle, the (!), and the VSC lights turn off and it drives fine. Should I give up on this car?
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Follow the advice the OP didn't. Read the codes and check for coolant movement.
  6. GinaCastano
    I saw that advice some time ago and I checked the pump for movement. There was movement and I also told the mechanics to check the inverter pump, but they always responded that the car was fine.
    I sought out hybrid mechanics who said that they could read the codes and even my local Toyota dealership failed to solve the problem.
  7. Moses Bruh
    Moses Bruh Member
    97
    29
    have you checked your 12v battery? Have you checked your engine oil level?
