Prius Loss of power, entering limp mode
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by FatCowKiller, Sep 16, 2019.
  1. FatCowKiller
    FatCowKiller New Member
    Illinois
    My 2010 Prius with 115k miles is having an issue with shutting off and losing power while driving, this started happening after having the software recall done a couple of weeks ago. The first time this happened the orange triangle came on with a check engine light, the hybrid system failure also popped up on the display, after a few hundred feet the rest of the warning lights went on and I lost any function of the vehicle, even gas motor and am not able to even get it into neutral (which is completely outrageous). After letting it sit for a couple hours the first time, restarting andit several times and adding fuel the warning lights all went off ( the error code I read was 3190). The issue occured again today when I had my obd reader connected same thing with the same loss of power. I noticed during the first phase of power loss the first inverter will shut off and during the second the second inverter will shut off. From what I've been able to see all the hybrid battery cells still look good, I am thinking possibly a bad fuel pump?? My oil still is relatively clean, although I will change it soon. Screenshot_20190916-071142.jpg Screenshot_20190916-071115.jpg Screenshot_20190916-070815.jpg IMG_20190916_071004.jpg Screenshot_20190916-071142.jpg Screenshot_20190916-071115.jpg Screenshot_20190916-070815.jpg IMG_20190916_071004.jpg Screenshot_20190916-071142.jpg Any advice would be appreciated.
  2. JC91006
    16,674
    8,519
    Bring it back to the dealer to diagnose. It should be free since this all happened after the recall. They usually have a 30 days warranty on their work
    Pluggo and m.wynn like this.
  3. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    no recall appointment for me.... /
    Grit, m.wynn and bisco like this.
  4. Grit
    Grit Senior Member
    6,456
    4,190
    Wilkes Land
    Planned obsolescence.
    Also if your oil is clean, why are you going to change it soon.
  5. Grit
    Grit Senior Member
    6,456
    4,190
    Wilkes Land
    Saved. Will be drinking to that with red wine after work.
  6. bisco
    51,157
  7. FatCowKiller
    Illinois
    I had it towed to the dealer, will have to see what they say this afternoon. I have little faith in them. The oil is at roughly 6700 miles, not too dirty right now but I like to not let it go more than 7-8k on synthetic.
  8. FatCowKiller
    Illinois
    The Prius codes all cleared at the dealer so they thought nothing was wrong with it apparently. I can tell they reflashed the software again, so they told me to take it back if it happens again. I had to coast the last mile home as the issue happened again, glad to see they test drove it -_-
  9. Shahzad Nayyar
    Shahzad Nayyar Junior Member
    94
    23
    Pakistan
    I might be avle to answer ur query tomorrow. I have a 2015 that goes turtle on an hour journey uphill. The problem is that the engine doesnt rev that high. No check engine, no codes just a turtle with 3 bars on traction battery. I ll confirm my results tomorrow and let u know
  10. Grit
    Grit Senior Member
    6,456
    4,190
    Wilkes Land
    How do you monitor that?
  11. Shahzad Nayyar
    94
    23
    Pakistan
    The engine was sounding even less than at 2000 rpm. U can hear a bit on the vdo. Otherwise obd fusion app
  12. Shahzad Nayyar
    94
    23
    Pakistan
  13. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    At standstil the engine can rev 2777 rpm, at 25 km/h it's around 3200 rpm. No idea what 8500 feet of altitude do to the engine.
  14. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    Does this happens, when the vehicle has being driven, or reached operating temperatures?
    When it stalls, does it immediately start-up, or you'd have to allowed the car cool down?
  15. Robert Black
    Robert Black New Member
    York, SC
    We're having the exact same problem, same code, same everything. Did you ever resolve this?
