Prius Lost All Keys SKS Smart Reset (Program Used Fob)
Discussion in 'Gen 3 Prius Main Forum' started by rup_pup, Feb 8, 2021.
  1. rup_pup
    rup_pup New Member
    Hey all,
    New member here. Not new to forums and because the 4 Prius' I've owned have been flawless, I never had a use to join this forum, but today I decided to join to share a little tidbit of information I learned. Now for the most part this is pretty intuitive to someone with mechanical and IT experience, but as more and more people start to tinker with their vehicles by themselves, it might not be to the average consumer.
    I will save the back story, but I had a Prius with no keys. They were for all purposes, lost and not going to be found. This led me down a rabbit hole of finding out that the only way to program a Prius SKS (Smart Key System) key fob is through a Toyota Diagnostic/Programming software called TechStream (TIS). Now this software can program new keys if you have an existing one, without much effort. There are some threads on Prius Chat that I've found useful that outline these steps. (See here: Techstream Key Fob Programming – Step by Step with pics | PriusChat)
    Now if you lose all your keys, you will need to do the "Smart Code Erasure" function under Smart Key > Utility menu. This will provide you with a "Seed Number" and will be either 6 or 96 characters in length (depending on what version of TIS you are using. This "Seed Number" will need to be inputted and calculated to return a "Pass Code Number" which will be required in TIS to complete this procedure. This "Seed Number" calculation can only been done legally by Toyota Authorized Dealers or Locksmiths who are licensed. Obviously the whole reason you are reading this is because you are a DIYer and with that I will say there are alternate methods to get the Pass Code.
    Once the Pass Code is inputted there is a 16 minute reset procedure/countdown. Once that is completed you can go back to the Smart Key > Utility menu and select "Smart Code Registration" and follow the instructions to register a new key. It will ask for an existing key, but you can ignore that step and just continue to register new fobs.
    This same procedure is the ONLY way to register used key fobs (that are linked to another Prius) to a new Prius. You can link a used Key Fob only if it has been "Virginized" which is to say that it is, for all intents and purposes, a new key "mentally." There are people/companies that offer this service. I've noticed that buying a new Fob (currently in 2021) is cheaper ($99) than buying a used Fob (~$50 - $75) and getting it "virginized" (using online services (~$25) I've found) or using this procedure to do a "Reset" and use a used fob. I would strongly advise against using a used Fob in a situation where you already have one working Fob. This hassle and the possibility of something going awry outweigh the $50 you will save. Only in a situation where I was already having to reset the SKS due to losing all keys, or if I have one readily available, would I even consider using a used Fob.
    This price does NOT cover the price of physically cutting the key blade which you insert into the door handle.
    All of this information has been posted before, but it took me 3 days of digging to find it and I hope a top level post will help anyone in the future.
    During this whole process I learned two things that I didn't run across or wasn't obvious.
    1) Have your battery 100% charged if possible! This is important. Either use a battery tester, volt meter and check, or just be on the safe side and take the battery out and take it to your local auto parts store to charge. The Prius battery is pretty small and can be fully charged in around an hour. Obviously the system will not stop you if your battery is low, but the last thing you need is it dying in the middle of the reset.
    2) The "Seed Number" changes and is only valid for 10 minutes (IIRC). Meaning if you close the program, or wait 10 minutes, the Seed Number will change and you will need a new Pass Code Number.
    3) Because you have no keys, you cannot start the car. Because you cannot start the car, TIS will NOT auto populate your VIN number. It will also NOT connect to your car automatically. You will need to manually input car information. When you select "Smart Key" in the main TIS menu it will NOT connect. At this point you will want to press the cars Power On (Push to Start) button. The car will give you an error that there is no key detected, but once the car is "awake" you can select the "Smart Key" function in TIS and it should connect to the SKS module and let you continue.
    Once again this procedure is ONLY for a situation where you have lost ALL your keys to the car OR if you want to program a used Key Fob to your Prius.
    Hope this helps someone in the future. I would strongly advise reading the thread I posted in this post to get familiar with the Toyota TechStream (TIS) software and screens that I mentioning in the post. I was in a hurry so was unable to capture the process to document.
    Priusdriver06, kc410, Valualv and 6 others like this.
    49,490
    very helpful, thank you!(y)
  3. Johnny Cakes
    Johnny Cakes Senior Member
    1,017
    765
    Virginia, USA
    Excellent post. Seriously, thanks!
    Is there a maximum number of keys that can be linked to the car?
    When my old Prius got rear-ended and totaled, I saved keys and wanted them programmed for the new vehicle. The tech spent about an hour trying before telling me it couldn't be done. The service writer told me he had tried to add keys to his vehicle and couldn't. I believe they said there were already too many keys registered, so I suggested wiping the whole thing and starting from scratch which, after another hour, worked.
    Not impressed with that dealership and so that was my last time there.
  4. tvpierce
    tvpierce Senior Member
    949
    879
    Maine
    2013 Prius v wagon
    Excellent info. Thanks for posting.
    I'm not sure about the above info though. I had only one fob when I bought my V used. I got a used, "virginized" fob on eBay for about $100 and was able to program it to the car as if it was a new fob. I don't recall having to do anything extra.
  5. jessanros
    jessanros New Member
    GA
    Thank you so much for the post, really helpful. Do you know if this will take care of the remote buttons (lock/unlock) in the new key?
    (I have two Priuses this is for a 2008)
  6. rup_pup
    rup_pup New Member
    First of all, sorry for the late replies. I never got notified of these replies!
    There is a max number, without going to the car and hooking up the software, I couldn't tell you what it is. Off the top of my head I think it is 4 or 5 however.
    Correct, if it is "virginized" then you can program it as a new fob. If you already have one fob, there is no need to do a reset. If you don't have an existing fob, then a reset is required, whether you have a used key, a new key, or a "virginized" key.
    This procedure is for 2010+ Priuses. Sorry can't help with an older model. I believe the software is able to do that however and program the buttons.
  7. jessanros
    GA
    Replying to my own comment above:
    This worked LIKE A CHARM. I used weboctopus and I got my code, which allowed me to reset the car codes. I got a silver logo key on eBay for ~$80 and everything worked flawlessly.
    Small thing to consider: my car's techstream options had slightly different names that OP's. Not a big deal. Also the remote functionality worked immediately after I registered the SKS. Cheers to saving money!
    Cyril Bouanna and tvpierce like this.
  8. tony_2018
    tony_2018 Member
    204
    61
    @rup_pup What version TIS did you use? I have suspicion that there might be more keys added to my prius so I want to wipe and re-add what I only have, plus a lexus smart card, and hopefully wipe whatever keys are in the system.
  9. Cyril Bouanna
    Cyril Bouanna New Member
    Bellevue
    Thanks @rup_pup!! Can you confirm that the full Reset procedure will work with a Used key fob?
    I lost my last key fob, so I'm looking at buying a seed online and using this Reset procedure.
    Can I get away with a used -non virginized- fob?
    Will I need to virginize it first?
  10. Cyril Bouanna
    Bellevue
    Thanks @jessanros!
    So you used a virginized fob?
    Or was it a used fob? rpup seemed to say that a used fob would work for the Reset proceduce...
    #10 Cyril Bouanna, Dec 13, 2021
  11. vvillovv
    vvillovv Senior Member
    3,664
    1,293
    NY
    #11 vvillovv, Dec 13, 2021
  12. Cyril Bouanna
    Bellevue
    Thanks @vvillovv, but I'm talking about the RESET procedure, required when you don't have another Fob left.
    The Chicken Dance is for Gen2s / duplicating an existing fob. Easier indeed.
    But when you have no Fob left, you need to do the more complex RESET procedure (needing a Seed etc.), but so then you can use a (cheaper) used fob? That's what @rup_pup's original post seems to say...
  13. vvillovv
    3,664
    1,293
    NY
    If you found the phone number of paul s shop in one of his post I linked above, give him a quick call during his business hours and I'm confident you'll get set of the right path for your current question.
  14. Valualv
    Valualv Junior Member
    Honolulu, HI
    Hi there. Thanks for your post. I am in a similar situation where I essentially don't have a key. I didn't lose it, but it got wet and no longer works. I purchased a new silver logo key and have been working through your steps in techstream. I purchased 5 tokens for the pin calculator and waited for the 16 minute reset. I was able to get it to where now when I stick my fob into the slot, the car will turn on. But, I cannot figure out how to get the smart key option and the door lock/unlock buttons to work. Any help would be appreciated. Thank you!
    Automatic and PriusGuy32 like this.
  15. So3da
    So3da New Member
    I just got both my keys water damaged, I can still run the car but only if I plug it into the car where it goes next to the wheel, can I use this one as a master still eventhough the smart functions are not working?
  16. Automatic
    Automatic New Member
    Im having the same issue as you! I’ve already done the immobilizer reset and the smart code reset. I can only turn on the car but the remote doesn’t lock/unlock doors, no proximity. I can’t find anything anywhere as to what to do about this issue or what causes it. Can anyone help please?
