prius lug nut
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ghatid, Apr 2, 2008.
  1. ghatid
    ghatid Junior Member
    22
    Los Angeles
    I'm sure this is in the forums somewhere, but I've been searching for awhile and I still couldn't find it. What size are the OEM lug nuts on an '07 prius? 21mm seems right, but I want to be sure before I buy one.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Just curious, but why do you want to buy a lug nut?
    Tom
  3. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    They are Toyota specific and pretty pricey. I believe Gorrila sells them so you can go to their website and look up your car.
  4. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    Perhaps he means he's buying a socket for his lug nuts... and not the lug nut itself?
  5. daveleeprius
    daveleeprius Heh heh heh you think so?
    429
    Seattle
    you can't find identical replacement lug nuts for the Prius, the $2 ones they sell at the dealership aren't as nice looking as the Japanese factory lug nuts.
  6. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
  7. ghatid
    22
    Los Angeles
    Woops, I'm an idiot. Yea, I'm buying a socket for the nut...Lol...thanks for the help on the lugnuts though:-D.
  8. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    it's 21mm, or 7/8; 6-sided
    either will work
    get a clicking torque wrench. Checker sell's a nice one with 1/2 drive for 35 bucks. Stay away from the gauge type, unless it's very high quality.
    use 76-80~lb torque
  9. Michou
    Michou Member
    Oakland, CA
    Actually, 13/16 is a better fit than 7/8.
  10. xsmatt81
    522
    Vegas
    yes 7/8 is a poor choice, just went out and tried it.
  11. hackIT
    hackIT Oceanic Member
    98
    Central Florida
    Just rotated my tires, and a 21 mm socket seemed to fit the best for me. :)
  12. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Another vote for 21.
  13. Patrick Wong
    18,200
    6,471
    13/16" = 0.8125"
    21 mm = 0.8268"
    I find that a 13/16" six point deep socket works great to remove the lug nuts, and this should offer a slightly better fit than 21 mm which is the official size.
  14. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    And what is the gauge type torque wrench exactly? And why stay away?
  15. Mike500
    Mike500 Senior Member
    2,593
    764
    Maybe NOT that important in this thread but the Toyota OEM lug nut is special, if you have alloy wheels.
    It has washers for the ALLOY WHEELS, but the tips are tapered to fasten the steel wheeled donut spare. The tapered area is very small, so I put standard tapered lug nuts in the trunk for use with the donut.
  16. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Yep, 21 mm and 13/16" are close enough that either is suitable. I actually use a 13/16" wheel brace to remove my lug nuts, and to spin them back on. I use a 21 mm socket + torque wrench just to tension them. The 13/16" is a slightly more snug fit. Personally I'd use that for the torque wrench too, except that my socket set is metric.
    This type: http://image.circletrack.com/f/techarticles/ctrp_1111_torque_wrench_myths/33032654/ctrp-1111-04-o%2btorque-wrench-myths%2bbeam-type-torque-wrench.jpg
    They're actually called a "torsion beam" type (or just "beam" type). The clicker type are easier to use. The beam type are mostly outdated now, but can still be quite usable if you own one.
    I've used both types and definitely prefer the clicker. The beam type has the advantage that you don't have to pre-tension/de-tension the adjustment spring before/after usage. But the disadvantage that you need to be able to position the wrench so that you can clearly see the gauge from a reasonably straight-on angle during usage. This is a major disadvantage in some situations.
  17. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    I see, thanks for the answer. I asked because in fact I got one beam type. It was 4 times cheaper than a clicking one.
