Prius Making "Brrrr" Noise As I Accelerate
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by xxbobbxx, Jun 1, 2015.
  1. xxbobbxx
    xxbobbxx New Member
    I just noticed today that when I accelerate my 2007 prius makes a weird noise. It has 200,000 miles on it and the noise it makes is like that of a import car with a pipe on it. Like I said in the title, the best way to describe it is a "brrrr" noise. Almost sounds like a lawn mower does when its running on "choke" mode. I'm trying to explain this the best way that I can. If I get a chance I'll upload a video or audio of the sound at a later time.
  2. JC91006
    16,496
    8,406
    You should have your exhaust system checked for leaks.
    49,735
    have you owned it since new, and has it had al maintenance and recalls completed?
  4. xxbobbxx
    xxbobbxx New Member
    I just had the oil changed this past weekend. I've owned it since 11,000 miles. Always kept up with the oil changes and other maintenance.
  5. xxbobbxx
    xxbobbxx New Member
    Might have to do that. It just started on my lunch break. Sounded fine this morning.
  6. bisco
    49,735
    running okay otherwise?
  7. xxbobbxx
    xxbobbxx New Member
    When I had the oil changed, Firestone recommended that I get the front-left bearings/hub changed. Said there was some movement but, I doubt that's it. Other than the noise, it seems to run just fine. Never had a real issue with this car.
  8. bisco
    49,735
    a bearing would make noise whether you accelerated or not.
  9. xxbobbxx
    xxbobbxx New Member
    That's what I was thinking. It only seemed audible during acceleration.
  10. bisco
    49,735
    jc is probably right, exhaust leak.
  11. xxbobbxx
    xxbobbxx New Member
    How serious is an exhaust leak? Is that a "need to get it fixed right after work" or "it can wait until the weekend" type of deal?
  12. JC91006
    16,496
    8,406
    Check your oil level to make sure it's correct too.
    I hate it when I allow other's to touch my car. My oil changes are done by a junior mechanic down the street from me. Last time he forget to put back 2 bolts that holds the plastic covers underneath the car back.
    My suspicion has just turned to the bearing as the cause of your noise.......
  13. bisco
    49,735
    no need to fix unless you need an inspection sticker.
  14. Mendel Leisk
    38,899
    You can get a general sense of the muffler health, by flopping down behind the car, take a look, how rusty, any rust-right-through. Also grab the tail pipe and give as much of a shake as possible, listen for rattles.
    If you're in a parking lot, just watch you don't get run over. :ROFLMAO:
  15. xxbobbxx
    xxbobbxx New Member
    You think it's the bearing? Even if it doesn't make it unless there's acceleration? I sure hope not. That's a $500 job at the very least.
  16. xxbobbxx
    xxbobbxx New Member
    Haha. Alright. I'll look at it before I leave work today.
  17. JC91006
    16,496
    8,406
    I only say that because a bad bearing would make that noise and you were just told there was a problem........so, that's the most likely cause.
    Physical inspections are way better than online guesses
  18. xxbobbxx
    xxbobbxx New Member
    I agree. I just thought the bearing issue would make a different noise. Thanks for your assistance!
  19. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
    Here's a different look at "expensive," repairs:
    $500/200,000miles = $.0025/mile.
    $500//7years = $71.43/year
    $500/8years = $62.50/year
    Now does $500 really look that bad now?
  20. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    both my '04 and '06 the muffler heat shield rusted through at the mounting stud. the head shield vibrated obnoxiously at times. I had to heat the nut with a torch cause it was seized on the stud so I didn't snap the stud off. then I used a fender washer to secure the heat shield.
    might want to have a look at the shield while your under there checking the exhaust out.
