Prius mechanic in PA
Discussion in 'Gen 3 Prius Main Forum' started by SCalpri, Jul 5, 2021.
  1. SCalpri
    SCalpri Junior Member
    Three Touring
    I just moved to PA and I was wondering if anyone can recommend a Prius mechanic near Scranton PA?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    51,140
    first order of business, if not already completed: egr circuit. thank you toyota. oh, what a feeling
  4. SCalpri
    Three Touring
    The engine light came on. Back in cali they said it had something to do with the battery temperature sensor. I had the spark plugs changed and the light came on only after that. Before that, my check engine light hadn’t come on. First they said the light was due to the O2 sensor and I had that changed. Light came on again the day I picked up the car from the mechanic. Took it back and they said it was now this temperature sensor or a new computer. Unfortunately, I had to move before the mechanic could figure it out.
  5. bisco
    51,140
    call woody and ask if he has tech stream diagnostic software
    Raytheeagle likes this.
  6. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    He's more of an old school mechanic;).
    But he may have the juice:whistle:.
    At least we know what some of the issues are(y).
  7. bisco
    51,140
    you can talk him through it :cool:
  8. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    If you can get a word in edge-wise:ROFLMAO::LOL::ROFLMAO::LOL:.
    He was gifted the gift of gab;).
    Put him with my old man and you have yourself a long day at the shop without accomplishing by much(y).
  9. SCalpri
    Three Touring
    What’s this egr circuit? Do I have to have that done? Ugh.. my prius was doing just fine before taking it to the mechanic :(.
  10. bisco
    51,140
    how many miles on her?
    the egr is 'exhaust gas recirculation' valve, for pollution reduction. the circuit is the whole assembly, including the intake manifold.
    but that is down the road. concentrate on the lights and trouble codes for now.
    are there any symptoms?
  11. bisco
    51,140
    besides, you have bigger fish to fry, you moved from the best coast to scranton :p
  12. SCalpri
    Three Touring
    2011 118k
    I really don’t feel any issues. The only thing I noticed is the mpg went down slightly after the spark plug and air filter change.
  13. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    :ROFLMAO::LOL::ROFLMAO::LOL::ROFLMAO:.
    @SCalpri , is the engine coolant level stable?
    Do you have the original list of codes the prior mechanic pulled?
    Good luck and keep us posted(y).
  14. bisco
    51,140
    they might have put in the wrong plugs, not torqued properly, loose wire, or even counterfeit plugs
  15. bisco
    51,140
    check the air filter and housing to make sure it is sealed properly
  16. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    What So Cal shop did you use for the work:whistle:?
