Prius mechanical expert advice needed
Discussion in 'Prius c Technical Discussion' started by crxnug, Oct 9, 2021.
  1. crxnug
    crxnug Junior Member
    dunnville ontario
    2014 Prius c
    I have a 2014 Prius c , The problem i having is radiator fan wont turn off unless i turn the car off, heater ac display does not work .my question is what can be the cause, If its a sensor does anyone have a picture of the location, and which part numbers for these, Any help would be much appreciated
  2. ChapmanF
    18,529
    It sounds as if you have at least two odd electrical problems, which are probably kind of peculiar to your car and will have to be tracked down with a multimeter and the wiring diagram (more info) kind of the old-fashioned way. At least, if it were mine, those would be my next moves.
    Any known accidents / flooding / rodents / other noteworthy history?
