Prius Motorcycle?
Discussion in 'Fred's House of Pancakes' started by kenmce, Oct 27, 2023.
  1. kenmce
    kenmce High Voltage Member
    1,528
    504
    NY
    I keep wondering what would happen if you pulled out the complete power train from a Prius, threw away everything else, and rebuilt it as a hybrid motorcycle. Given the cumbersome weight of the traction battery, the gas engine, the planetary gear, MG-1 and MG-2 you might want to make it a three wheeler. Given the complexity of the existing battery and energy management system you might want to scrap the computers and roll up your own, rather than trying to spoof the existing system.
    You think it would work?
    49,401
    Might be easier and simpler to use the guts from an ev
  3. bwilson4web
    15,513
    Once upon a time, I read about someone trying to fit a Prius drivetrain into the body of the original Honda Insight. The Honda Insight had a problem drivetrain ... the mechanical CVT.
  4. Leadfoot J. McCoalroller
    7,140
    6,688
    Pennsylvania
    2018 Prius c
    Okay, a Prius trike.
    I imagine you'd have the stock engine & transmission above the rear axle line, and then set up the battery so that it stood up on one of the thin edges (its nominal front or rear) along the centerline, below the seat. Relocate the radiator to the rear, behind the engine.
    Saddlebags over the front wheel to (each) hold a few ECUs.
    It would make for a very heavy trike, but it might be fun.
