Prius MPG Starting Number
Discussion in 'Prius c Fuel Economy' started by mariahx91, Jun 7, 2015.
  1. mariahx91
    mariahx91 New Member
    Los Angeles
    2015 Prius c
    Hey i had a quick question. My friend and I both got the 2015 prius c. She got type 1, i got type 2.
    I noticed that on hers, her mpg consumption starts at 99.9 all the time and mine seems to start from 0.
    Is something wrong with mine or is there some kind of setting that was turned on?
    #1 mariahx91, Jun 7, 2015
    52,390
    welcome! i don't have a c, but am curious to know what others are seeing.
  3. donnalaf
    donnalaf New Member
    fort myers florida
    Mine starts at 99 and works its way down. 2012 Prius C. Gray
  4. CR94
    CR94 Senior Member
    2,749
    1,205
    Northwestern S.C.
    I suspect that was merely because, after resetting the trip mileage, she drove at least a some initial short distance with the engine stopped, thus briefly scoring infinite miles per gallon burned during that brief period. (It shows 99.9 if the quotient is over 99.9.) If your engine runs before the car moves significantly, you'll see 0 mpg, because that's the truth---temporarily. Longer-term, the difference is of no significance.
  5. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    I've seen both. 99.9 only if car moved sufficient distance w/o engine (usually backing up since it is all electric). If engine started then it is 0.
    If you moved car in EV mode, then it preserves prior MPG count. Irregardless either readout is erroneous due insufficient distance to preform accurate calculations.
  6. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    Irregardless, agh, say no to unnecessary made-up words! That's my pet peeve talking, as I've seen it used a few times lately. Must. be. expunged.
    Yoshiyyah and CR94 like this.
  7. NateDoubleU
    NateDoubleU New Member
    Indianapolis
    2015 Prius c
    I am a trained linguist and most certainly, irregardless IS a word. It is in the Merriam-Webster dictionary and has been in use since 1912. Please watch this video to learn more
    . While irregardless is indeed a word, I would not recommend using it in discourse that involves the scrutiny of pedants such as vinnie97. Refraining from its use in these situations may be ideal for those who wish to avoid elitist language "guardians." That said, this is a forum for the Prius and not for language wars. I rest my case.
    Yoshiyyah likes this.
  8. CR94
    CR94 Senior Member
    2,749
    1,205
    Northwestern S.C.
    It's not in my Merriam-Webster, which is newer than 1912, so I can't guess whether it means the same as "regardless" or the opposite (as in "irregular," etc.). Why be ambiguous, when there's a less dubious, less ambiguous related word that's also shorter?
    Yoshiyyah and vinnie97 like this.
  9. cyclopathic
    3,292
    547
    2014 Prius c
    Sincere apologies for starting religious war. Burn heretics! behead infidels!
  10. NateDoubleU
    Indianapolis
    2015 Prius c
    As I had originally mentioned, this is a forum for Prius related topics, not language wars. As such, I am not interested in misinformation espoused by pedantry. Therefore I will contribute to the actual topic at hand.
    In my experience, both may happen depending on certain variables. My MPG begins at either 0.0 or 99.9 depending on whether or not the engine is turned on by the car's computer at startup. If EV mode is activated from start up and continues to remain active as I begin to drive, my car begins with 99.9 MPG. If the gas-engine is activated at startup, then my car begins with 0.0 MPG. To me this is logical because when starting my drive with the engine turned on I've gone nowhere while using gas thus 0.0 MPG. If I start to drive in EV mode, I am, of course, not using gas and thus beginning at 99.9 MPG. My suggestion is to pay attention to your car's starts and your friend's car's starts and see if this is the reason for the differing MPGs when starting.
  11. vinnie97
    1,430
    277
    Somewhere out there
    Well, Nate, language is how we express ideas, and we should strive to do so as clearly and concisely as possible. As a "pedant," I couldn't agree with CR94 more.
    Here's Dictionary dot com's remarks about its origin:
    Made-up confirmed. Leave it in the dustbin of history. ;)
    Actually, since you're namecalling from your ivory tower, I think I'll just give you the honors of being the first added to the ignore list. Just realized that was your first post to the forum...good grief.
    I will admit that "irregardless" does appear in the hard copy Houghton Mifflin dictionary I have in possession. It also confirms the nonstandard use referenced in dictionary.com's description, but it completely redirects to "regardless" instead of providing a definition.
    #11 vinnie97, Jul 30, 2015
  12. ufourya
    ufourya We the People
    1,258
    336
    42
  13. carolD
    carolD Junior Member
    82
    florida
    2015 Prius c
    I am getting about 45 mpg using my Eco. I have only had the car 3.weeks. Is that good? Should I use the ego button? Does the mileage get better the more you drive it. ?
