Prius Mudguards?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by DreamcastDC, Jun 28, 2007.
  1. DreamcastDC
    DreamcastDC Junior Member
  2. Tom_06
    Tom_06 Active Member
    609
    141
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(DreamcastDC @ Jun 28 2007, 03:34 AM) [snapback]469267[/snapback]</div>
    Yes. But only into plastic. Unless you don't mind crooked screws, you also have to remove the rear wheels to drill the backs. The front wheels can be turned enough to not need removal.
    - Tom
  3. Swanny1172
    Swanny1172 New Member
    666
    Very easy to install. 20 minutes top if you are using a floor jack.
  4. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    Yes to drilling.... into plastic as mentioned. But don't worry about it being reversible. The mudguards look nice when they're on and no reason to take them off again. I got tired of spray up the side of my lovely clean car if I hit anything remotely wet. I'm very glad I put them on.
  5. Doc Willie
    1,717
    142
    Out there, somewhere
    <div class='quotetop'>QUOTE(Ichabod @ Jun 28 2007, 08:54 AM) [snapback]469316[/snapback]</div>
    Hmmm. What about when they get old, brittle, and start to crack, split, and pieces start falling off.
    Sorta like me.
  6. MarinJohn
    MarinJohn Senior Member
    3,945
    304
    <div class='quotetop'>QUOTE(Doc Willie @ Jul 9 2007, 05:58 AM) [snapback]475471[/snapback]</div>
    Then time for a face lift! Start a rainy day fund now.
  7. Ichabod
    1,794
    Newton, MA
    The holes needed are not in an awful spot, so if you choose to (or are forced to) remove the mud guards at any point, you could probably get away with leaving the holes as they are... You could also plug them with epoxy or something if you're worried about water/muck getting in there. They'd be barely noticeable unless you're looking for them.
  8. Tom_06
    609
    141
    <div class='quotetop'>QUOTE(Ichabod @ Jul 9 2007, 02:48 PM) [snapback]475659[/snapback]</div>
    Put the fasteners back in the holes after removing the mudguards and they are plugged and invisible.
    - Tom
  9. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    the mudguards are always a good addon for car, especially in wet climates. Here in neveda dont normally need them, but they are nice for wet puddles and for keeping small rocks from making scracths accros bottom fenders
  10. esears1
    esears1 New Member
    30
    I got my yesterday and installed them right away. Took me 20 mins with a floor jack... Very easy install. Makes the car look nice!
  11. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i purchased mine in 04. they are still looking. They tend to hold up pretty well. i have a habit of bottoming out when i go up hwy 9. the mud guard is the first thing that hits. it's a little flat on the bottom. I do that a lot. :playball:
  12. patsparks
    10,664
    567
    Adelaide South Australia
    If your mudflaps get old and fall apart get new ones. If it was a good idea to have mudflaps in the first place it's a good idea to replace them if they break. So no need to worry about ugly holes.
