Prius Nav System + iPhone + Wireless + Pandora
Discussion in 'Gen 3 Prius Audio and Electronics' started by Advance The Man, Apr 15, 2011.
  1. Advance The Man
    Advance The Man New Member
    49
    Cannot figure it out. Anyone have luck with the iPhone 4 and the Pandora app to work via bluetooth?
  2. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Not per se but it works fine with my iPhone 3GS. What exactly are you having problems with: Bluetooth seeing the phone or the app not working?
  3. Advance The Man
    49
    Using BT for calls works fine. Play pandora on iPhone and dont see how to tell it to play via BT.
  4. bdiddy
    bdiddy New Member
    NC
    Yes, I have an iphone 4 and use Pandora with it all the time. I also use Instacast for streaming podcasts to it.
    Since phone calls are working, you got it paired as a phone, you also need to make sure you add the iphone as an auxiliary bluetooth audio device. That setting is under the Setup menu for Audio I think....
  5. Tideland Prius
    16,125
    bdiddy's got it.
    You have to pair it for BT Audio as well (but just like BT phone, it'll auto-pair once you've set it up)
    SETUP --> Audio --> Bluetooth Audio Settings and add the device.
  6. Bullet220
    Bullet220 New Member
    17
    Renton, WA
    Got my Pandora working - thanks to all!
  7. adizon
    adizon Junior Member
    52
    89
    SF Bay Area
    Hmmm, only 3.5 weeks into owning my new to me 2010 Prius with JBL Nav system. Didn't even know I could do this, thanks for the info fellas, I'll give it a try!
  8. Ank
    Ank Junior Member
    San Francisco, CA
    It works seamlessly for me - but initially, it didn't...because I tried to overthink it, and used different passwords for the two bluetooth profiles exposed by the car! As soon as I made the passwords the same, it worked beautifully.
  9. adizon
    52
    89
    SF Bay Area
    Thanks again, this worked. Now I can stream Pandora, or my iPod from my phone!
