Prius nav system
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ralpherga, Nov 10, 2007.
  1. Ralpherga
    Ralpherga New Member
    Has anyone had a problem with the navigation system getting lost. I recently drove from Pittsburgh, Pa to Atlanta, Ga and on my approach to Atlanta the navigation system lost track of the exits on I285 and lost track of my distance to destination. Both never recovered even when I tried to suspend guidance and restart the guidance.
    Any help. This is a 2007 prius. :(
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Did the NAV system continue to show your correct position on the map while guidance was confused, or did it lose your position? If the position is lost, then you lost the GPS signal, otherwise it could be a map database problem for that area. More information may help us diagnose the problem.
    Tom
