Prius not accepting gas
Discussion in 'Prius c Main Forum' started by Josh331, Dec 10, 2021.
  1. Josh331
    Josh331 Junior Member
    47
    Coeur d'Alene ID
    I’ve had this problem before but then it went away. Now it does it constantly. Car acts is if it’s full despite being on empty. Takes me 20 min to fill my tank with constantly having to click the nozzle, it’s beyond annoying. AND it only lets me fill up to 7 gallons? What in the heck is going on and is it a simple fix?
  2. dbstoo
    dbstoo Senior Member
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
  3. ChapmanF
    18,889
    You can follow along in this thread (it is about a Gen 2, but I don't think the Gen 3 and c ORVR systems are a whole lot different, other than lacking the Gen 2 bladder).
    One thing you may notice while reading through that thread is that the original poster there had a habitual way of filling up that tends to contribute to the issue, and so even after paying for repairs and being "confident to say the problem is resolved", ended up starting another thread for the same issue about eight months later, to nobody's very great surprise.
  4. Pri3C
    Pri3C Active Member
    183
    131
    Midwest
    2014 Prius c
    Just chiming in to let you know that only being able to put 7-8 gallons in a Prius C tank is normal and not part of the issue you’re experiencing. I think when the range is at 0 miles and the tank is “empty” there’s still a gallon or so left as a reserve. My C usually takes about 7.5 gallons to fill it up.
    dig4dirt likes this.
  5. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Unplug the evap and blow compressed air in the hose to clear
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    There should also be some kind of "anti-siphon" flap in there and it could be causing the problem too.
    You are inserting the nozzle in as far as you can, right ?
    And it is going in as far as the spring will allow it to, right ??
    I agree that the 7 gallons is normal.
    My fills usually are closer to 6.
  7. ChapmanF
    18,889
    Before following any suggestion about your fuel system that has the words "compressed air" in it, please go through pages 5 to 7 here.
  8. sam spade 2
    7,035
    2,804
    2017 Prius c
    Pages 5 to 7.....where exactly ??
    I agree that mixing compressed air and fuel can be really dangerous.
  9. ChapmanF
    18,889
    In the PDF file that results from clicking on the blue word "here".
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    Pretty hard to notice that.
    At least for my screen colors......and when the word "here" is on a new line by itself.
