Prius not being driven for a long time. How to keep the battery healthy?
Discussion in 'Gen 2 Prius Main Forum' started by ProspectivePriusPeruser, Nov 26, 2021.
  1. ProspectivePriusPeruser
    ProspectivePriusPeruser Junior Member
    50
    Australia
    Hey all,
    As the title says, my prius is going to be sitting for a decent amount of time (1 year max). Is there anything I should do to keep the battery happy?
  2. nancytheprius
    nancytheprius Member
    231
    77
    iowa
    drive a little bit weekly (the more the better). at the minimum at least start it and let it do a full warmup cycle weekly
  3. dolj
    dolj Senior Member
    5,872
    3,123
    Wellington, New Zealand
    When you say sitting, what do you mean exactly? Will it be stored and you will be absent or will you just be leaving it sit while you drive another vehicle?
    If the latter the easiest thing would be to regularly drive it at least twice a week for 30 - 40 minutes each time.
    If the former, you will need to have some kind of charging routine for both batteries. You will need to have a regime for the tires too.
  4. Another
    Another Active Member
    759
    184
    Naples, Florida
    Maybe give it to someone to use
  5. bisco
    43,208
    yeah, that's not a good thing. you can force charge it before leaving it. but if no one can drive it regularly, or put a grid charger on it, you risk death by stagnation
  6. ProspectivePriusPeruser
    50
    Australia
    I figured that it wouldn't be any good for it. I'd probably be able to have someone start the car and leave it running for a while every so often, but it being driven during this time is almost impossible. Would that be of any help to it?
  7. bisco
    43,208
    yes, you don't need to drive it. once a week for a half hour or so would be great, but the more the better.
    sitting for a long time lets the cells slowly go out of balance, especially on older batteries.
    the bms will correct that every time you make it ready
  8. Leadfoot J. McCoalroller
    4,456
    4,399
    Pennsylvania
    2018 Prius c
    No clue what the market is like down there now, but if it were anything like in the USA? I'd just sell the car and go get another in a year or so.
    Another and bisco like this.
  9. Another
    759
    184
    Naples, Florida
    Rent it out as a stationary Prius camper on Airbnb
    Climate controlled
  10. Another
    759
    184
    Naples, Florida
Loading...
