Prius not charging 12v with p0a08
Discussion in 'Gen 2 Prius Main Forum' started by kolez2000, Sep 12, 2023.
  1. kolez2000
    kolez2000 Junior Member
    64
    West Africa
    This 2007 Prius came with the triangle light and came with code 264 as detail code. The car is not charging 12v battery. I changed the inverter with another car own and the inverter works fine on the other car.
    When I returned it to the car, it will not charge the 12v battery. If I jump start the car, it will start but the moment I remove the cable, it will discharge the battery and go off. Who as experienced this before. I need advice on what to do. The car keep going off
    @bisco
  2. Tombukt2
    Tombukt2 Senior Member
    13,405
    2,415
    Durham NC
    Back in the battery area the 12 volt is the sense wire connected and seated good that's the single white wire coming out over there on the far right of the black plastic terminal mount for the plus side of the battery have a look not the fat white wire that kills the whole 12 volt system in the car if you unplug it so that's good for it quick reset The one next to it to the right of that the single thin wire Make sure that's not about to break that needs to be connected there so that the inverters circuit can sense the state of charge of the 12 volt. Check it out
    52,384
    has the 12v been load tested?
    what code did you get?
  4. kolez2000
    64
    West Africa
    P0a08 DC)DC converter circuit status. I tested the battery and it was 11v. I jump start the battery to 12.35v and the car would start but it goes off in few minutes as it is not charging the 12v battery. I load test it when the car is on but the battery voltage drops and the car would go off
    #4 kolez2000, Sep 12, 2023
  5. kolez2000
    64
    West Africa
    Thanks, I will check and update you.
  6. kolez2000
    64
    West Africa
    Let me add one thing I did. I jump start the Prius with another Prius and it worked perfectly while the wire for jump start was connected. But the moment I disconnect the cable, it throws the triangle light with the code p0a08 inverter circuit status.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Battery nearly stone cold dead.
    OR.....depending on that connection points you are using for the jump,
    you might be "bypassing" a bad main battery connection when you do that.
  8. bisco
    52,384
    I think you need a new 12v, the car won’t charge it that fast.
    Can you try the one from the jump start car?
  9. kolez2000
    64
    West Africa
    Thanks
    Thanks car fixed. The cable from the inverter assembly came off that is why the car was no charging the 12v battery. It was connected and the car works perfectly now. Thanks.
  10. bisco
    52,384
    congrats!
    kolez2000 likes this.
  11. pasadena_commut
    pasadena_commut Senior Member
    2,830
    844
    Southern California
    It just fell off? Was work previously done in this area? I don't recall reading in this forum about that cable ever spontaneously detaching.
  12. kolez2000
    64
    West Africa
    Someone worked on it previous
  13. ChapmanF
    18,537
    That's the kind of thing passive voice was invented for.
    "Cables were detached ...."
