Prius not getting up to speed over 60
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MileHighHybridOwner, Jun 13, 2020.
Tags:
  1. MileHighHybridOwner
    MileHighHybridOwner Junior Member
    36
    Boulder
    Hi
    So I took my old faithful out for a drive today along the highway. She was quite lumpy accelerating with a gradient up the highway. Anything over 60 was sometimes difficult to overtake when I got stuck behind a semi truck.
    I’ve noticed this kind of behavior before.
    Absolutely fine around town but just feels a bit “laggy” on the highway at high speeds. I tried turning off the ac to see if this helps but I didn’t see any difference.
    Rain hit and kind of ruined the day so ended up turning back from a big drive - but don’t want to experience this in general on long trips.
    Anyone else experienced anything similar - I have 2005 model.
    Thanks
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Are there any abnormal lights lit on the dash? Check engine or big red triangle?
  3. MileHighHybridOwner
    36
    Boulder
    The engine check light comes on but then goes off - I think this is related to the combination meter issues that I am having though and I actually posted this in another thread
    No warning light and no engine check generally
    52,677
    how many miles on her?
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Let's see.......you have a 15 year old vehicle, with how many miles on it ? (a lot probably).
    AND you live at a high altitude.
    My first thought is that ANY car that fits that description might exhibit similar performance.
    There are just a lot MORE things that can cause it with a hybrid.
    Both main power sources are suspect: The gas engine and the hybrid battery.
  6. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Can you clarify this? Is it on for minutes and then clears by itself? Blinking on and off? It's on today, but off tomorrow?
  7. MileHighHybridOwner
    36
    Boulder
    It comes on with the dash when I start it but I get the black dashboard of doom and can’t see my speed etc... so I do the usual “fix” and go to the trunk and pull the power cord for about 60 sec then put it back in.
    That usually fixes the problems.
    Then I don’t see it again once the dash is fixed
  8. MileHighHybridOwner
    36
    Boulder
    145000 miles - pretty low for that age of vehicle.
  9. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    Do you have a way to check for error codes and battery health (techstream or obdii bluetooth adapter with Dr. Prius app)?
    If not, Paul at Boulder Hybrids knows more about these things than just about anybody. Have him take a look.
  10. MileHighHybridOwner
    36
    Boulder
    I’m not sure I have even heard about any of these diagnostics... I just need a reliable dash and to be done with all of these issues.
  11. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    A good option is Matt at TexasHybrid. He can program one to match your mileage, send it to you and then you send him your old one back. Very fair prices, and they've been refurbished.
    Texas Prius Battery Replacement
    SFO likes this.
  12. royrose
    1,389
    953
    Foot of Pikes Peak
    the fastest way to be done with these issues is to have an expert diagnose them . I don't think Boulder Hybrids would charge a lot for the check up but fixing the problems could be costly depending on what's wrong.
    If you want to try to save some money, you will have to learn how to do some checks on your own. An OBDII bluetooth adapter plugs into the vehicles diagnostic port under the dash and connects by bluetooth to your phone. There are several apps that can give you info. The Dr. Prius App will test the health of your hybrid battery which, if it is a "refurbished" one, may be beginning to fail.
    If you search for OBDII on Amazon you can find adapters to buy. The Dr. Prius App's web site can give you more info on what the app does and how to choose an adapter: Hybrid battery diagnostic and repair tool for Toyota and Lexus
    Techstream is the software that Toyota dealers use to diagnose problems. It can give lot's of info but is more complicated to obtain and use than an OBDII adapter as described above.
    SFO and Raytheeagle like this.
  13. sam spade 2
    7,035
    2,804
    2017 Prius c
    Then take it to Toyota and pay them to fix it.
    Or trade it in.
    Easy. But maybe not cheap.
  14. MileHighHybridOwner
    36
    Boulder
    Not an option.... maybe Boulder Hybrids is a good shout.
  15. royrose
    1,389
    953
    Foot of Pikes Peak
    I live about 100 miles away but will consider taking my Prius there for major service when/if major work or preventative maintenance is needed.
    Either way, let us know what happens.
  16. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    What does the battery SOC show on the MFD during these driving situations ?
    Here is a thread on how to fix the combination meter yourself : combination meter repair - DIY | PriusChat
