Prius not idling when Li battery is low.
Discussion in 'Gen 2 Prius Main Forum' started by Rob Stone, Oct 10, 2012.
  1. Rob Stone
    Rob Stone Junior Member
    49
    Portsmouth Ohio
    I have attempted to look through the forums for a problem that I am having with my 2004 Prius but I had no luck. I got stuck in traffic for over an hour yesterday and my Prius' engine would not idle and charge the Li battery. There were two bars of charge showing on the display, and the engine would start, but would quickly stumble and die. It would continually attempt to start, but stumbled each time and died. The engine ran fine, and the Li battery recharged once I was out of traffic. It also starts fine when it is cold. Is there possibly a control module failing when it gets hot? Could a weak 12 volt battery cause this? Need advice. I work on my own Prius. Does Prius Chat have schematics for this version of Prius available?
    Thanks for your assistance! :)
  2. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    The battery is not a Li battery it is a NiMh, that aside is not the cause of your problem. The most likely cause is a dirty throttle body causing the throttle to stick. This can easily be cleaned (look up throttle body cleaning in the search function).
    Spark plugs are also a possibility on a 2004 Prius as you do not say how many miles it has done.
    Rob Stone likes this.
  3. Rob Stone
    49
    Portsmouth Ohio
    Hey thanks for the corrections! Spark plugs have been changed out at factory suggested intervals. All batteries are original and pushing 251,753 highway miles on them. I will check the air filter and I can check the throttle body. That should be a piece of cake. I found a thread about using the MFD to view battery status. Going to try that as well. Thanks for your response!
  4. Britprius
    5,194
    1,918
    The MFD is ok as a comparison guide to battery condition, but if you have a volt meter that is much better.
    I have done a small amount of research on this and find that the MFD displays in my reseach always under read the battery voltage by up to .5 volts. Not saying yours will be this far out but worth checking as half a volt is the difference between a fully discharged battery and one with a 75% charge.
  5. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Not PriusChat but, there are downloadable technical manuals at:
    Documentazione Tecnica Prius 2006
    Prius V.2 Documentazione Tecnica Prius 2004
    manual pdfs are in english
    The 2004 manual covers 2004-2005 Prii
    The 2006 manual covers 2006-2009 Prii
    The 2010 Manual was just the owners manual when I last looked at it.
    JeffD
  6. Britprius
    5,194
    1,918
    Electrical schematics are in the file library at the bottom of the gen2 page.
  7. Rob Stone
    49
    Portsmouth Ohio
    Hey thanks everyone! Batteries appear to be ok and charging system appears to be ok via onboard diagnostics. Looked down throttle body and it is gummed up. I hear a crusty sound when I move the butterfly via twisting it. Sounds like the motor gears need cleaned on the throttle body. Will be cleaning throttle body this Saturday with my chief automotive technician (12 year old son). I am also going to check the inverter? coolant pump behind the driver's side headlight for correct operation. I will keep searching the forums and checking here for more information. Trying to hit 300,000 miles. Again, thank you all very much for your input! :)
  8. Rob Stone
    49
    Portsmouth Ohio
    I estimate that I will reach 300,000 miles on it in approximately 12 months.
  9. Britprius
    5,194
    1,918
    Along with all the others on this forum glad to give what help we can and your thanks goes a long way.
    John (Britprius).
