Prius not starting any suggestion on what could be going on?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ruisustyle, Mar 16, 2022.
  1. Ruisustyle
    Ruisustyle Junior Member
    Four Oaks, NC
    Hey folks, I have an 05 Prius that's been sitting around for almost two months now. I cant believe I forgot to check here, but here is what happened.
    While driving home late at night, my Prius shifted to neutral when I got to a stop light. It was very odd, but I simply tried putting it into Drive and keep going and nothing happened. I could not go into Park, Drive, Reverse, it was just stuck at Neutral. If I recall correctly, the Red triangle was also on.
    My solution was to try and power cycle the car, so I turned it off and back on, unfortunately, this did not fix anything even worse, the car would not go into ready mode or even properly come on. The red triangle went away, but so did everything else on the dash. When trying to turn the car on, the following lights turn on for less than a second (BREAK, MAINT REQ, Low temp light, Brake system warning light, ABS, VCS, Slip indicator). My Odometer will briefly flash along with the outline for the PRNDB (this flashes twice) then shut off.
    The Radio and lights still work, but the AC was dead. I unplugged the 12 volt waited a bit, but nothing changed. I ended up getting towed and my car has just been sitting there till this day.
    Any suggestions as to what could have happened?
    At this point, I’m not in a big hurry to fix it as I’ve purchased a car, but I’d life to bring back my prius to life (if possible).
    Now, if this wasn’t enough of a problem, I have lost my last keyfob for the Prius, I still have a spare mechanical key to unlock it and get into it. But I’m not sure where that leaves me at this point.
    I spoke with a Toyota service guy who apparently checked with a hybrid friend of his and they suggest that it’s possibly the hybrid battery.
    I kinda hope that this is the case, since I would be able to order a replacement battery and then tow it to Toyota and hopefully get keys made.
    What are you’re guys thoughts?
    Picture of the Dashboard (had to go frame by frame on a video to get the odomoter one)
  2. JC91006
    16,674
    8,519
    It seems you might have a dead 12v battery right now to do any type of diagnosis. You also might be having the combination meter problem where your dash won't light up. That's a problem that is happening to all the older 2nd gen prius cars
  3. Tombukt2
    Tombukt2 Senior Member
    12,215
    2,155
    Durham NC
    did it not display park on a level surface on mfd??????
  4. JC91006
    16,674
    8,519
    Are you headlights on?
    Tombukt2 likes this.
  5. bisco
    51,155
    12 volt
  6. rjparker
    rjparker Tu Humilde Sirviente
    9,597
    5,894
    Texas Hill Country
    Normally a 12v battery won't strand you while the system is running since the inverter's dc to dc converter supplies the 12v at that point. A hybrid battery that codes out typically can be reset with a 12v power cycle and usually won't strand you while driving. An inverter failing could strand you as could various wiring faults.
    You need to read codes with a Techstream scanner. After two months the 12v is discharged and will require a jump or new battery just to begin a diagnosis.
    Without a keyfob you can't even try to Ready the system so buying a hybrid battery, inverter, combination meter or brake booster won't be definitive even if one of them is the issue.
    I think step one is to find the fob or take the car to a dealer to have a new fob programmed. At that point a 12v jump and a Techstream scan will further diagnose the issue.
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    I'll throw this out there just for the heck of it. The symptoms you had on the dash are indicative of a significant drop in 12v power. This could be a hard failure of the 12v battery significantly loading down the DC-DC circuit, or it could be the inverter cooling pump failing and drawing the voltage down significantly on the AM2 circuit. If the ICWP, it usually pops the AM2 fuse and totally kills the car, but I have seen it blow the fuse, but not completely. Still enough metallic contact to let a minor amount of voltage/current pass to cause intermittent flashes of warning lights. Unplug the inverter cooling pump, verify the AM2 fuse is not partially blown (it happens) or just put a new one in, and make sure you have a solid 12v battery. Try the car again see what happens. I guess it would be important to get a new key first though, lol.
  8. Ruisustyle
    Four Oaks, NC
    Thank you everyone for the input. I'll be towing the car to Toyota soon and see where things go. I've been hunting for this key for weeks with no luck. And yeah, that's going to suck. I'm not sure if I should just scrap the car at this point.
    I appreciates everyone's time and input.
  9. Another
    Another Senior Member
    1,818
    515
    Naples, Florida
    Sell it to @Tombukt2
    He’s in NC
    Always in the market for another parts car
  10. Tombukt2
    12,215
    2,155
    Durham NC
    He's in 4 oaks just came thru there an hour ago too. 9198920363 if it gets to no go stage let me know
  11. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Anyone have a better voice to text program to sell him? I honestly feel he has knowledge and experience to share but I think most people just skip his posts because the current VTT he's using makes his posts mind numbing
  12. Another
    1,818
    515
    Naples, Florida
    I quit the NYT crossword puzzle and just do @Tombukt2 daily to keep my brain active.
  13. Tombukt2
    12,215
    2,155
    Durham NC
    He right up road . Was they’re yesterday.
  14. BuyJapanese
    BuyJapanese Member
    62
    31
    Wisconsin
    Sounds like a shorted inverter coolant pump causing a blown fuse that prevents the car from starting. Check your AM2 fuse (15amp, labeled AM2 on the diagram on the inside of the under-hood fuse box).
    There was a recall and a TSB on this way back when, it doesn't come up much anymore. BUT...I have recently discovered...that some aftermarket inverter coolant pumps can cause the same problem.
    IF your AM2 fuse is blown, you can circumvent the problem temporarily by unplugging the inverter coolant pump. No tools needed, just reach down there behind driver's headlight and unplug it. Then put in your spare 15A fuse, then try to start it and see what happens. If it starts and runs with no issues, you know you have isolated the problem, so you can then order a new pump. Stick with OEM.
