Prius one Radiator, A/C leak. Patch or replace?
Discussion in 'Generation 1 Prius Discussion' started by Michael S., Jun 25, 2022.
  1. Michael S.
    Michael S. New Member
    Temple City, CA
    2001 Prius
    Hello Everyone,
    First post here. I have a Prius one with 253k miles on it.
    About 30k miles ago, I started noticing my a/c was running out pretty fast. When I took in my Prius to replace the brakes (1200, suspiciously high), the mechanic said my A/C was running out so fast because there was a leak in my Radiator pipe, and since they were connected on my car, I would also need to replace the radiator... for another 1,200 dollars in total.
    I've been driving in socal summer with no A/C to play it safe, but I decided to give it a look myself. It looks like the leak is right near the bottom, and seems fairly small. Do you think I could just patch it up? If so... how do I do that? I was a boyscout and have some experience with tools, so I feel pretty confident if it's a quick fix.
    Here's a video of the link. Let me know what you think, and thanks!
    Best,
    Michael
  2. dolj
    dolj Senior Member
    7,634
    3,850
    Wellington, New Zealand
    Isn't that the A/C evaporator drain hose? If so, you can expect that to be dripping, especially if the humidity is up there. I would be looking somewhere at the front of the car, where the condenser is, from what your mechanic said. Look for a pipe that goes from the compressor and goes toward the radiator. The A/C condenser is usually in front of, on top of, or at the bottom of the radiator.
    Hopefully, someone will be along soon to say where it is on a Gen 1.
  3. ChapmanF
    15,509
    In Gen 1, the engine radiator and A/C condenser are combined into a single part (with different connections for the engine coolant and A/C refrigerant, of course).
    But even though it's a funky combined part, it's really not that expensive, even at dealer list price.
    The rest would just be labor for coolant drain and refrigerant capture, replacing the thing, and filling and recharging.
    You might be able to find somebody to do that for less than $900.
    "Hybrid specialist" A/C shops are in order for Gen 2 and later, because of the high-voltage electric compressor and need for special oil, but a Gen 1 just has a belt-driven compressor like the ones any A/C tech grew up with. Nothing fancy.
  4. Josey
    Josey Active Member
    290
    110
    Virginia
    2003 Prius
    Refrigerant doesn't leak as fluid so you won't be able to find the leak by looking for that. dolj was right that what you're seeing is just condensate dripping. You won't be able to repair it either, so radiator replacement is about it, but I'm sure you can find a better deal on getting it done.
    And it will leak whether you use the AC or not, so you might as well use it.
  5. ChapmanF
    15,509
    Well, the condenser pressure is likely to be around 80 to 100ish psi or so if you're not using A/C, compared to 225 or so with the A/C in use, so it's likely to leak faster if the A/C is in use.
    On the other hand, when the repair is done, that will involve reclaiming all the refrigerant that's still inside and then adding a full charge after the repair, and as far as I know, it's not typical for a shop to credit you for the amount they took out, so it's kind of moot.
    I did once manage to get a credit for what came out, when I was repairing an old R-12 system after the stuff was phased out and really expensive, but I had to talk to a couple layers of management, write letters, and watch the tech like a hawk to make sure he wrote down the weight that came out.
