Prius opens by itself
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by supradan7, Mar 1, 2011.
  1. supradan7
    supradan7 New Member
    United States
    Hello, I tried searching around if anyone else has the same problem but I failed, that or I just didnt look hard enough. Well heres the deal, I have a 2004 Prius. Just rolled 120k today, still running like a champ, but I started having this weird issue. Whenever I walk up to the car, it opens by itself.I dont even have to put my hand on the door handle, I just get close to the drivers door and it opens, of course with the smart key in my pocket. Its only the drivers door as well. I find this a little weird plus its hard to lock the door with the black square because if I dont run out of range...it unlocks. If anyone would have a link and/or a possible fix, that would be awesome. Its not really a severe problem but I would like to get it done soon.
    Thanks for future notice,
    Dan.
  2. Stormtrooper1
    Stormtrooper1 New Member
    MN
    I would guess that the sensor on the drivers door is dirty or something.... Maybe there is a little mud or something up there that it's detecting, and thinking it's your hand.
  3. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Gee......I wish mine would do that.......
  4. dogfriend
    7,512
    1,189
    Carmichael, CA
    I think the capacitive sensor in the drivers door handle is bad - it is activated all of the time, so when your smart key is in range it unlocks the door.
    As a work around to lock the door, you could use the button on the fob to lock the door after you get out of range (about 1m or 3 ft)
  5. MXZDrew
    MXZDrew New Member
    MI
    New (used) Prius owner here! I thought that was how it was supposed to work! Same issue here on my 05' with 83k on it. I'll be watching the thread for a fix myself. Thanks!
  6. bisco
    51,140
    that would be sweet! i lock mine at the trunk anyway, i can never tell at the door if it beeps or see the lites flash,
  7. Rest
    Rest Active Member
    1,210
    CA
    It opens or do you mean it unlocks?
    The car doesn't have the internal mechanics to physically open the door by itself. If yours is, then you have some kind of paranormal activity going on. :eek:
  8. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Yep sounds like a sensor situation where it always thinks there is a hand there. Perhaps Thing from the Addams Family is nearby? :)
    Clean the door handle area thoroughly and see if it goes away.
  9. Lilian
    Lilian New Member
    Chicago
    2015 Prius+ MPV
    I am currently renting a prius from Turo and
    the same thing is happening to me. I was very shocked.
  10. bisco
    51,140
    the door actually opens? i would love that
