Prius over heating light on Toyota couldn't fix
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by impulse7675, Aug 9, 2016.
  1. impulse7675
    impulse7675 New Member
    Oregon
    I have a 2007 prius with 112,000 miles. I replaced the coolant control valve and coolant. I removed all the air out of the system. my wife drove 700 miles to her family with everything working perfect. Now the car's over heating light is on. The car I believe wasn't actually over heating. Coolant is full, pumps working, no leaks. My wife took the car to Toyota and worked on the car for 2 days. They replace 1 sensor and it still doesn't. I know there is not a lot of info. I'll post the diagnostics from Toyota once I get it.
  2. JC91006
    16,477
    8,394
    I'm sure Toyota will get to the bottom of it.....at your cost. If everything was working fine before you replaced the 3 way valve, then you probably did something to cause this overheating episode.
    But the 3 way coolant control valve you replaced has nothing to do with it overheating. Maybe air in the system.....but Toyota would know more
  3. Patrick Wong
    18,200
    6,472
    It would be very easy to prove or disprove your belief, by using an instant read infrared digital thermometer to determine the temperature of the cylinder head, the radiator hoses, etc.
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I am betting Toyota has not seen your car, just a dealer. If they are clueless, try another dealer. Toyota themselves has no service departments, although they do send out folks in warranty cases, if the dealer asks.
    It is somewhat like calling tech support, if your tech seems clueless, hang up and call again.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Did you replace the engine water pump belt? Because if you did it would have given you a chance to spin the water pump and see what condition its in and with a flashlight look for green specks splashed around in that area reflecting the water pump bearing is shot and its leaking out of the water pump weep hole.
