Prius P0420 Code - Bad Cat. Converter?
Discussion in 'Gen 2 Prius Technical Discussion' started by Bryan Holloway, Jun 23, 2016.
  1. Bryan Holloway
    Bryan Holloway Junior Member
    43
    Fullerton, Ca
    I have this code. I have checked the live data with my reader and am trying to diagnose this to see if it could save me a catylitic converter. I just dont know what to look for in the live data. This shot was taken with engine warm at 2500 RPM. I also measured the inlet and outlet with a thermal temp gauge of the converter and temp seemed about the same.
  2. Bryan Holloway
    43
    Fullerton, Ca
  3. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    If you can monitor you downstream O2 sensor and see erratic readings or high voltage, you can confirm P0420.
  4. Bryan Holloway
    43
    Fullerton, Ca
    So my upstream is "O2S B1 S1(V)" and its pretty constant around 3.3V as seen in the video, which is really high correct? I read its supposed to be below 1V. Does that indicate a bad sensor, or lean mixture or something?
    The downstream "O2S B1 S2(V)" seems to jump between .2-.4. But my reader isn't really "live" it just updates every few seconds.
    #4 Bryan Holloway, Jun 23, 2016
  5. Bryan Holloway
    43
    Fullerton, Ca
    Anybody able to help me with this issue? I need to fix asap as i need to renew the registration =(
  6. Patrick Wong
    18,200
    6,493
    3.3V is correct. That indicates an air/fuel ratio of 15 to 1 which is nominal. The first sensor is an air/fuel ratio sensor, not an oxygen sensor.
    You need to replace the catalytic converter.
    Bryan Holloway likes this.
