Prius parasitic electrical current when parked.
Discussion in 'Gen 3 Prius Technical Discussion' started by William11348o, Sep 10, 2023.
  1. William11348o
    William11348o Junior Member
    57
    Hawaii
    Can anyone tell me what my gen3 parasitic current should be when parked? I am getting 0.5 amps in park and the battery is discharged completely after several days. Am I seeing signs of a short?
    Oops my bad. I should have known that this questioned has been asked and answered by this awesome group. I had the hatch open, assuming there was no sensor. Will try again with hatch closed.
    After tightly closing back hatch parasitic current dropped to 0 after a couple of minutes. With hatch ajar current was 0.44.
    #1 William11348o, Sep 10, 2023
    51,155
  3. Mendel Leisk
    40,586
    I got around 18 milliamperes, with spikes to around 40~45 every 5 seconds or so, which might have been the security icon on the dash.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    NO. Assuming that your lights are normally all OFF......and the parasitic current is close to ZERO.......
    then you are seeing signs of a 12 V battery reaching the end of it's life.
    How old is your battery ?
    Outside chance it's not being charged enough but that almost never happens.
    Well except for folks who make only short trips between many days of non-use.
  5. Mendel Leisk
    40,586
    That's us. Our 8 year old battery lives spends all downtime connected to a CTEK 4.3 smart charger, tests like a new battery.
    @William11348o what's your usage like?
  6. William11348o
    57
    Hawaii
    Battery is an Optima and is supposed to be realatively new. Need to ask previous owner if its still in warranty.
  7. sam spade 2
    7,035
    2,799
    2017 Prius c
    Optima started out being pretty good.
    Then they got BAD.
    Based on reports from owners.
    I don't know the current thinking but the glowing praises
    of Optima just aren't there anymore.
  8. Mendel Leisk
    40,586
    Our’s is an optima yellow top, installed September 2015, still testing like new. Could be prior to rumoured quality-drop though.
    Full disclosure: we are LOW usage, but I have it hooked up to a smart charger ‘round the clock during idle times.
