Prius Persona Owner Question
Discussion in 'Gen 3 Prius Main Forum' started by StreetGhost, Apr 21, 2015.
  1. StreetGhost
    StreetGhost New Member
    24
    Minneapolis, MN
    Can someone tell me if the Persona badge has holes behind it like the other badges or is it only taped on?
  2. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    223
    Nature coast, Florida
    Three Touring
    Never took mine off, but it appears to be stuck on...
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    If you take it off, I'm sure someone with a non-Persona will want to stick it on their car. :ROFLMAO::rolleyes:
    StreetGhost likes this.
  4. cantsitstill
    cantsitstill Junior Member
    Saw that thing off with some heavy fishing line behind the badge. Let it sit in the hot sun, or gently heat it with a hair dryer and take it off. The balance of the sticky goo can be removed by rolling it off with your fingers. Think, trying to get that spot off your smartphone with your fingernail, only use the tip of your finger.
    I hate extra badging.
  5. StreetGhost
    24
    Minneapolis, MN
    I too hate extra badging and have removed most if not all of them on most cars I have owned. This is however the first car in which so many mounting/post holes are used for the badges. While I like a badgeless car I am to cheap to have them filled/painted but still want to remove them when I can. I found a 3M product that works wonders for removing badge gunk.
    So people are 100% certain there isn't any posts/holes associated with the Persona badge? Again I can't imagine they would have went through the hassle of making more holes for the limited (relatively speaking) number of Personas that are out there but want to be sure.
  6. StreetGhost
    24
    Minneapolis, MN
    Can I get a definitive yes or no from a Persona owner that has removed theirs?
  7. Tim Lucchino
    Tim Lucchino Junior Member
    Lancaster, Ca.
    I can tell you that on a 2013 there are no holes behind the Persona badge but, the Prius & hybrid badges both have two hole each.
  8. yumseyo
    yumseyo Junior Member
    Hey Tim, do you possibly want to sell your old persona badge? thanks, yumseyo
