Prius PHV battery
Discussion in 'Prime Technical Discussion' started by PiotrLe, Jan 18, 2020.
Tags:
  1. PiotrLe
    PiotrLe New Member
    Coventry UK
    2018 Prius PHV
    Business Edition
    Fully charged my battery on Thursday night and the car was not used on Friday. On Saturday, I noticed the battery is empty again which means the batter lost all charge in less than 48 hours. Is this normal?
  2. schja01
    schja01 One of very few in Chicagoland
    1,746
    1,162
    Chicagoland
    2018 Prius
    Not normal.
    Could be a bad battery or something is putting an unwanted drain(parasitic) on the battery.
  3. Bob Comer
    Bob Comer Active Member
    708
    457
    South Carolina low country
    Definitely NOT normal. I've had my car sit for a week and it not lose any of the charge.
    49,507
    any chance you left the car on?
    drash and Prime Alex like this.
  5. FuelMiser
    FuelMiser Senior Member
    1,300
    888
    Monument, CO
    If the car's in READY mode, it will keep the traction battery at least viable in the HV portion of the SOC. No way it would run all the way down.
  6. FuelMiser
    1,300
    888
    Monument, CO
    Did you leave the charger plugged in the entire time?
  7. jerrymildred
    jerrymildred Senior Member
    11,513
    14,118
    Tampa, FL
    Welcome. You didn't give us a lot to go on there. Several questions come to my mind to help figure out what happened since those batteries don't self discharge like that. And one comment.
    The comment is that it's wise to pay attention to the owner's manual when it says that it's not good for the battery to leave it fully charged for long periods. If you want it to last as long as possible, charge it right before you use it.
    Questions.
    Have you had the car for a while and are you familiar with the charging scheduler?
    Are you absolutely certain it actually did charge?
    When you plugged the EVSE into the car's charging port, did the green light in the port blink several times and then go out or did it just come on and stay on. The former indicates that it's going to wait till the next scheduled charge while the latter says it's charing immediately.
    I ask because until you get familiar with the system, it's super easy to assume that it will charge but then it doesn't because of some oversight in the scheduling or other assumption.
    Rob43 likes this.
  8. schja01
    1,746
    1,162
    Chicagoland
    2018 Prius
    Could the OP be referring to the 12volt battery?
  9. bisco
    49,507
    i thought he meant 'empty of wall charge', sorry.
    sonds like a trip to the dealer for recharging.
