Prius PHV - Production battery cells
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by usbseawolf2000, Feb 15, 2012.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    I was comparing the specs from the 2010 prototype plugin with the 2012 production version spec from the owner's manual. Here are the specs (2012/2010):
    Voltage: 3.7V / 3.6V
    Capacity: 21.5 Ah / 5 Ah
    Quantity: 56 / 288
    Overall Voltage: 207V / 345.6V
    The production cells are much bigger so the quantity dropped from 288 to 56, wow! It'll take all 56 cells x 3.7V to reach the 207V pack overall voltage. This means all 4 modules would have to be used together at the same time. There is no more active/inactive module stuffs from the prototype.
    Simtronic likes this.
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    That threw me off too. So I took a look at the wiring diagram.
    Of interest, the 150A fuse, which dictates a limit of 30 kW for propulsion.
  3. mitch672
    mitch672 Technology Geek
    1,077
    197
    Randolph, MA
    What 4 modules would that be? It appears to be 1 large single pack now...
  4. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
  5. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    Interesting. At 207V, max is 31 kW.
  6. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
  7. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    JP sales staff manual says max 38kW battery power.
    I don't know the JP PiP fuse rating.
    Ken@Japan
  8. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Thanks, Ken.. hopefully its 38kW for the USDM PiP
    ("Thanks" still works on Tapatalk on my iPad :p)
  9. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    3.7 V is a nominal, not max. voltage for certain Li-XX chemistry cells. Max. voltage for 3.7V nominal cells is 4.2V.
    So, with 56 cells, that would make it a 235V max voltage. Ok, it's going to be a little lower, since the cells won't be fully charged - only to about 90% SOC.
    4.2V * 56 cells * 150A = 35kW.
    However, these fuses are made to withstand more amps for short bursts (10 seconds) that they are rated to, so 38kW power is possible.
  10. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Japan and US versions may be different with respect to max battery power (which corresponds to max load still in EV). However, this corresponds also to EV efficiency and (blended mode) range.
    38 kW is nice but it lowers the EV efficiency and range as compared to (say) 31 kW. Since EPA label is the yardstick for efficiency, I personally prefer lower kWh/mile and higher Rcda on the label even if this means the ICE is joining earlier.
    Another aspect may be battery loads, battery life expectation and warranty.
  11. Flying White Dutchman
    4,374
    313
    fom 3.6 to 3,7? what type of lithium are they using?
  12. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
  13. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    I think you have it backwards. ICE joining earlier means the MPGe drops and potentially 0 EV miles (if the EPA requires EV miles to be driven at a speed where the ICE kicks in).
  14. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    It depends on how much MPGe gets boosted vs the hit in MPG. The difference between 38kW and 31kW will not make it 0 EV miles. Toyota already said you can get 10-15 EV miles with speeds up to 62 mph.
  15. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    This is what I found. It is made by Sanyo which is part of Panasonic group, per this press release.
    This is what the cell looks like:
    This is from the battery guru (Dr.Anderman):
    He said top executives at Sanyo, the world’s largest lithium battery producer, told him the company is only developing two automotive-size cells for the near-term future—5-A·h cells for HEVs and 21-A·h for PHEVs and EVs.
    “Two sizes, that’s it—if you want it, this is what they offer,” he noted. “But concentrating on those two cells, Sanyo will get performance and reliability up and cost down. Later they’ll develop probably an EV cell, similar to the PHEV cell but higher energy or a different cell size.”
    Sanyo’s 21-A·h cell was designed for Toyota’s new PHEV architecture. The company also offered the same cell to Audi (who is buying it), as well as offering it to Ford, he said. Toyota, Hitachi, and some other leading battery makers have the same philosophy as Sanyo’s—limit the complexity and focus engineering resources on fewer cells and fewer configurations.
    Will Ford be using the same Sanyo cells in their Energi plugin cars?
    2 people like this.
  16. sxotty
    sxotty Member
    224
    28
    Pittsburgh
    Bigger cells have many drawbacks, cost just isn't one of them.
  17. Flying White Dutchman
    4,374
    313
    thx
    not to bad compared to the lifepo4 used with lots of DIY EV these days
    LiCoO2 0.518 kW·h/kg
    LiFePO4 0.495 kW·h/kg
    not sure about the A123 prismatic pouches ( also used in the fisker? )
  18. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Excellent research. Thanks!
    The same article also says:
    The NMC movement
    In Dr. Anderman’s lastest forecast, nickel-manganese cobalt (NMC) and the cylindrical metal “can†appear to be emerging as the predominant cathode material and battery-cell package, respectively, for automotive use going forward. Battery companies that started with nickel-cobalt aluminum (NCA) have migrated or are in the process of migrating to NMC because they made more development progress with it and have found its inherent safety “is a little easier to manage.â€
    Likewise, several companies that started with the lower cost, very safe lithium-manganese oxide (LMO), including Hitachi and GS Yuasa, migrated to LMO/NMC blends and are now moving to NMC to achieve greater energy density.
    The LG Chem cells used in the Volt are an LMO/NMC blend which, the article notes, is the near-term trend in the industry because it performs well and has inherent safety advantages over NCA.
  19. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Here's a link to an earlier thread where I described what is known about the cell used in the Volt.
    http://priuschat.com/forums/prius-h...hv-available-winter-2012-a-5.html#post1450614
    I also included links to some source material. One especially interesting and recent one is a NASA comparison of 4 cell designs for possible use in space missions. One cell is from A123, 2 are NMC-based from Dow-Kokam and EIG, and the final is the cell design used in Volt.
    The cells are compared under a 4C discharge rate so some of the quoted numbers are lower than they would be if quoted under the usual industry practice of 1C or even lower discharge rates.
    See slide 8 for a 4C rate comparison of the complete cells.
    http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20120000040_2011025423.PDF
    There is some additional description of the cells in an earlier preliminary report:
    http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20110011197_2011010830.pdf
  20. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Where in my post did you find any mention of MPGe? I was speaking of EV efficiency (in terms of miles/kWh).
    As I understand (and correct me if I am wrong) if the the ICE kicks in during the test then EPA reports EV miles as Rcda (actual charge depleting range) rather than AER (all electric range) and these will certainly not be zero!
