prius plug-in 2014 NSZT-W62G Toyota back reverse Camera reverse guide line setup
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Mohammad Nazrul Islam, Oct 10, 2021.
  1. Mohammad Nazrul Islam
    Bangladesh
    2014 Prius Plug-in
    Hello friend my prius plug in car model 2014 dvd player model NSZT-W62G ,some day ago i remove battery connection for service car,after connect again battery my dvd player i seen reset & when unlock erc code then back Camera reverse line not show ,after i try to configuration but when select model phv then not answar select model. Help me if anyone know prius plug-in 2014 NSZT-W62G Toyota back reverse Camera reverse guide line setup .
    Thanks .
    52,391
    we don't get reverse lines, i hope someone who does sees theis and can help
  3. Sarge
    Sarge Senior Member
    1,325
    785
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    First, are you *sure* the car had backup lines before? I have a 2014 North American model (Canada), and it does not support the backup lines, but I believe this feature was added in 2015. However model options and feature may (and likely will) be different in Bangladesh.
    I am pretty sure there should be a setting to enable/disable the lines if you poke around in the menus? Maybe if you put it in reverse to pull up the camera then touch the screen, like options when adjusting contrast/brightness? Sorry I can’t be more help.
    Good luck! (y)
