Prius plug-in vs standard hybrid
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Kidze, Jan 3, 2019.
  1. Kidze
    Kidze New Member
    Europe
    Hello,
    what i would like to find out is the reason for difference in the performance between standard prius gen 3 and prius plug-in gen 1.
    As far as i know, plug-in version takes about 1 second more from 0 to 100 km/h than standard prius (approx. 10,5 sec vs 11,5 sec), even though it is only a little bit heavier, negligible for such difference in acceleration data.
    Is it because control system of the power-train operates differently or is it something else?
    I would really like to hear the impressions of the people who had driven both cars, is there any difference in the feel how much power there is available in each car with full throttle?
    Thank you in advance.
  2. Deoc
    Deoc Member
    70
    39
    Pasco
    2014 Prius Plug-in
    If you buy a prius and worry about 1 second between the normal and plug in, then i think you are buying the wrong car (no trying to be rude just opinion) the plug in is heavier thats probably why, the suspension is slightly more robust but no noticible difference, the plug in is usually more expensive, but if you can get the plug in for the same price as the normal you will want to get the plug in, better battery and you could get better gas milage if you dont charge it.
  3. Kidze
    Kidze New Member
    Europe
    No offence taken
    I am not planning drag races, but still the car has to be useable in everyday life, i.e. it has to be powerfull enough to pass a truck on some road in some time which is not dangerously long.
    So that's why it bothers me is the plug-in version noticably slower than regular prius or not.
  4. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    You made me curious. I googled and found 0-60 Times | Find 0 to 60 & Quarter Mile Times Car Specs
    I compared the two and they said this:
    I'm not aware of any tuning differences between them. I do know that weight makes a big difference in acceleration. It also impacts fuel economy as I noticed yesterday while making a 50+ mile trip with a heavy friend.
    That said, my PiP's acceleration is enough for me. If it wasn't, I'd still have a sport touring motorcycle. ;)
  5. Kidze
    Kidze New Member
    Europe
    Thanks Jerry.
    I guess that there is no big difference, but if someone has driving experience of both cars, please share your impressions.
  6. jfschultz
    jfschultz Active Member
    635
    114
    Germantown, TN
    2013 Prius Plug-in
    How our perspectives have changed. When I learned to drive 0 to 60 in ten seconds was a hot car!
  7. QuantumFireball
    QuantumFireball Active Member
    419
    268
    Ireland
    I've only test driven a few standard Gen 3 Prius briefly, didn't really feel any difference between them and mine.
    One thing to note since you're in Europe: There is no "PWR Mode" in the Plug-in, as it's replaced by "EV City" mode (which further restricts ICE usage). But this just changes the linearity of throttle response - flooring it in normal HV mode isn't any different to PWR mode.
    SFO and jerrymildred like this.
  8. Kidze
    Kidze New Member
    Europe
    Thx for info. I would also expect that they are more less the same, but i found on toyota.uk faq page (i can't put a link as a newbie) the info that li-ion is 40 kg heavier and plug-in is 1 second slower than standard prius, which makes no sense to me, 40 kg is the weight of a kid, it cannot make the difference in performance.
    That's why if thought there is something else, maybe something in control system which puts more accent to the fuel saving other than performance.
  9. Tideland Prius
    16,128
    Final Scoring, Performance Data, and Complete Specs
    10.2 secs naught to 60 according to Car and Driver. I’m pretty sure the regular Prius doesn’t do it in 9.2. (Closer to 9.8 IIRC)
  10. QuantumFireball
    419
    268
    Ireland
    Yeah, the 0-60 figures don't make sense. I don't think they're that useful anyway for normal driving, something like 30-60 MPH would be more relevant.
  11. Mendel Leisk
    38,669
    A lot of Prius drivers are content to stay in line with the trucks, good for the mpg, easier on the nerves.
