Prius Plus/Alpha Li-ion Battery Busbar Cleaning
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Ohid, Jul 23, 2021.
  1. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    I want to clean my Prius Alpha Li-ion battery Bus bars and connectors cleaning. Does anyone in this group do cleaning of corrosion of Li-ion battery bus bar and connectors. Want to know the details of opening the Battery covers and cleaning process since its construction is little different than Nimh battery. A video will be very helpful. TIA.
  2. Tim Jones
    Tim Jones Senior Member
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    Have you tried you tube? Countless prius videos there
    privilege likes this.
  3. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    I searched google but no luck. Most of the videos made for Nimh battery but my one is Li-ion battery.
  4. Tim Jones
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    Do they look the same?
    Are the connections similar?
    Do you have a picture?
  5. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Post here Battery pictures with its duct, bus bar and connectors. Each block containing 7 cells. Total 8 blocks with 56 cells.
    This Battery pack placed under center console Between two front seats.
  6. Tim Jones
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    Did you get a new battery or just decide to clean the terminals?
  7. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Just clean the terminals for preventive maintenance.
  8. Tim Jones
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    They can look pretty nasty but I think most of the time cleaning them makes no difference.
    Probably the only time they really need cleaned is when you replace the battery.
  9. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Thanks for your answer. But many people suggests to do so to reduce internal resistance and temperature.
  10. Tim Jones
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    Guess so...but I did it at 2000,000 miles and made no difference in any voltage readings. I did get new bus bars when I replaced the traction battery.
    Just because the bars look dirty doesn't affect the internal resistance of the bar.
    Best on these is to just leave them alone till you get a new traction battery.
  11. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Is there any impact on
    Internal resistance and temperature after cleaning?
  12. Tim Jones
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    As long as the copper is clean where it connects to the battery terminals is all that matters.
  13. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    This copper is rusted as well as bolts and connectors are corroded should not impedes the current flow?
  14. Tim Jones
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    It only matters where the copper touches the battery. The circle that is clean....
    Ohid likes this.
