Prius Plus not starting / ready Help needed
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by CNP, Mar 26, 2021.
  1. CNP
    CNP New Member
    UK
    2012 Prius+ MPV
    Hi this is my 1st post and help is needed. Thanks
    Prius Plus 2012 import, 70k miles
    Tis techstream fault codes shown U0131 (steering control unit) photo added
    No codes on standard diagnostic equipment
    Hybrid Battery around 35%
    12v battery replaced
    Fuses checked.
    Car stood parked for a few months.
    Could be a possible power drain on the car also.
    Tried jump starting also
    52,363
    might be a blown fuse. whar are you getting for voltage at the jump point under the hood?
  3. CNP
    CNP New Member
    UK
    2012 Prius+ MPV
    When I checked the voltage under the hood. At jump point and fuses. It matched the battery voltage. It was 12.5v last I checked. Battery is drained again.
    The car seems to be draining the 12v battery.
  4. CNP
    CNP New Member
    UK
    2012 Prius+ MPV
    I have checked fuses under dash and in the engine bay. I may check them again visually and with a multimeter
  5. CNP
    CNP New Member
    UK
    2012 Prius+ MPV
    Would a power steering control unit stop the car from starting/ready?
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Leaving the scanner tool plugged in will drain the battery too.
    You didn't mention recharging the battery manually. Have you done that ?
    New batteries often come half charged or less.
  7. CNP
    CNP New Member
    UK
    2012 Prius+ MPV
    Hi i do double check to take the scan tool off.
    New battery was 12.1v I manually charged it to 12.9v
    While on charge the hybrid battery seem to be charging up at 0.06v. From 38% to 59% but 12v battery drain to 5v.
  8. CNP
    CNP New Member
    UK
    2012 Prius+ MPV
    The pack voltage looks low still
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    I think this is the first time I've ever seen a techstream readout from a Plus model.
  10. CNP
    CNP New Member
    UK
    2012 Prius+ MPV
    Hi the graph is read out from hybrid diagnostic app.
    The codes are from Tis techstream program
  11. CNP
    CNP New Member
    UK
    2012 Prius+ MPV
    The fault may possibly be the voltage sensor unit on the hybrid battery. As Tis could not reset or do a diagnostic on the battery pack
  12. ZX Nutt
    ZX Nutt New Member
    Jacksonville, FL
    My 2012 V will not start if the 12v battery is low.
  13. CNP
    CNP New Member
    UK
    2012 Prius+ MPV
    I have had the 12v battery over 12.6v of charge and my car still doesn't start
  14. CNP
    CNP New Member
    UK
    2012 Prius+ MPV
    Visually checked the hybrid voltage sensor and plugs for burns marks etc. They look clean 20210328_143743.jpeg
  15. sam spade 2
    7,035
    2,804
    2017 Prius c
    Well yes, that would be pretty much true of almost ANY vehicle.
  16. ZX Nutt
    ZX Nutt New Member
    Jacksonville, FL
    Correct, but the Prius spins the engine with the 220v traction battery, not the 12v...
  17. CNP
    CNP New Member
    UK
    2012 Prius+ MPV
    Manually charging the hybrid battery would be nice. It could be the next option.
  18. bisco
    52,363
  19. bisco
    52,363
    that would be unusual for a low mile '12 after a few months, but anything is possible i suppose.
    still, if everything else were fine, it should boot right up and tell tis the hv battery is low.
  20. sam spade 2
    7,035
    2,804
    2017 Prius c
    Yes but the 12 V powers the computers that TELL the engine to start.
    I guess I'm not getting your point.
