Prius Plus/V 178K miles things to change
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by faisalak7, May 28, 2023.
  1. faisalak7
    faisalak7 Junior Member
    46
    UK
    2013 Prius Alpha
    Active
    Just bought Gen3 prius plus or V in US or Alpha in Japan 7 seater, its an import from Japan to UK , it has 178k miles everything so far on the car is original never changed , what i am planning after reading loads of threads online are
    - water pump
    - inverter
    - pcv valve
    - all the coolants
    - oil and filters
    - break oil
    Any thing you guys suggest to check, spark plugs were chaged 40k miles before. Coils i am not changing they are out of my budget right now .
    By the way the car is working fine no issues so far. Mostly its will be used for short runs, getting 40 to 42 mpg.
    Many Thanks
  2. JC91006
    16,827
    8,600
    If it's from Japan, they are very strict on the emissions, but I can't imagine the mileage being that high, Japan is not that big and this car has to be on it's 3rd or 4th engine by now
    Tim Jones likes this.
    52,371
    does it have egr valve?
  4. faisalak7
    46
    UK
    2013 Prius Alpha
    Active
    Imported in 2018 with 45k miles , and used as taxi , engine is still factory fitted, nothing is done to it yet.
  5. faisalak7
    46
    UK
    2013 Prius Alpha
    Active
    I think it does, the whole point of this discussion is to avoid big bills in future, so what do you suggest
  6. bisco
    52,371
    if it is similar to north america, the egr circuit clogs and potentially blows the head gasket.
    @Mendel Leisk has all the details for cleaning in his signature.
  7. Mendel Leisk
    41,882
    Top two links in signature; if on a phone turn it landscape orientation to see signature.
    faisalak7 and bisco like this.
  8. faisalak7
    46
    UK
    2013 Prius Alpha
    Active
    Thanks Mendel
    Tim Jones and Mendel Leisk like this.
  9. Tim Jones
    Tim Jones Senior Member
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    To bad that's the miles when everything starts going bad................... be prepared for Blown Head Gasket......
  10. faisalak7
    46
    UK
    2013 Prius Alpha
    Active
    Right so what we saying here these cars are not worth after these miles, even after doing all that stuff head gasekit will still go ?
    if its that bad should i sell it then .
  11. Mendel Leisk
    41,882
    If the EGR system (including the EGR passages in the intake manifold) has never been cleaned, for 178k miles, it’s likely to be very clogged with carbon, and consequentially there’s a good chance the head gasket is failing, or will be soon.
    getting on the cleaning is always good, may avert head gasket failure, but with those miles I wouldn’t count on it.
    faisalak7 and Tim Jones like this.
  12. Tim Jones
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    Sell it and get a Non Hybrid...... unless you financial and metal pain..................
  13. faisalak7
    46
    UK
    2013 Prius Alpha
    Active
    So, this is what I am thinking to do all at the same time, Water pump, thermostat, PCV valve, Full EGR cleaning, intake manifold cleaning.
    Not sure how long it will take but I must do this sooner than later.
    Do you know where is the fan location of HV battery in Prius V.
  14. faisalak7
    46
    UK
    2013 Prius Alpha
    Active
    So far there are no known symptoms, I may take the risk and keep it for couple of years.
    Looks like electric is the only solution with no traditional engine parts or servicing .
  15. Mendel Leisk
    41,882
    I suspect it’s similar to 3rd gen Prius, it’s right next to the battery. If that’s the case you need to pry the hatch deck off the top of battery, remove the fan air intake grill at rear seat back (one 12 mm bolt, reachable by pushing apart seat and seat back), then just follow your nose, pull out the ductwork till the fan is uncovered. I’ve found you can clean the fan in place; no need to remove.
  16. faisalak7
    46
    UK
    2013 Prius Alpha
    Active
    That's what I thought but fan is not there
  17. Mendel Leisk
    41,882
    Look for the hybrid fan air intake, and follow it? I’ve also heard the inlet can be on the front of the rear seat, near the the floor.
  18. faisalak7
    46
    UK
    2013 Prius Alpha
    Active
    its under the front right hand seat , that looks like a tough job .
  19. bisco
    52,371
    probably easier to go from the battery. are you sure that's the battery intake? looks more like a booster fan to move conditioned air to the back
    #19 bisco, Jun 5, 2023
    Mr.Greenjeans and Mendel Leisk like this.
  20. faisalak7
    46
    UK
    2013 Prius Alpha
    Active
    Right folks update, manage to change water pump , thermostat , pcv valve, engine and inverter coolant, cleaned the egr valve and pipe also the throttle body , intake manifold and changed the gasket for manifold, it was leaking hence the oil on the protection shield .
    These are some of the random pictures.
    upload_2023-6-20_1-3-31.png upload_2023-6-20_1-4-27.png upload_2023-6-20_1-4-49.png upload_2023-6-20_1-5-16.png upload_2023-6-20_1-5-37.png upload_2023-6-20_1-6-6.png
    Manifold was not bad at all looks like the last owner did clean it.
    Water pump looks perfect and was moving freely with good magnet.
    Egr cooler was not bad so did not take that out.
    Thanks guys for your help, did this kind of work first time broke only one bolt and it took me 4 days to finish the job after work. I hope this car lasts bit longer now.
    The most difficult part was to put back the under sheet and to remember where all the bolts and nuts will go.
    @Mendel Leisk found lots of good info from your posts especially the diagrams and torque specs
    below youtube channels helped
    The Car Care Nut and NutzAboutBolts
    Now to next project is parking sensors, rear looks not too difficult but for the front ones not finding any information .
    Mr.Greenjeans, bisco and Mendel Leisk like this.
