Prius Power ON problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dvizzy, Sep 17, 2017.
  1. Dvizzy
    Dvizzy Junior Member
    46
    Alabama
    Four Touring
    Hello! I have a Prius that suddenly stopped working while driving. Had to pull over and get it towed. The 12v aux battery was fine. The power button won't start the car when the FOB is the key slot. Any ideas?
  2. Patrick Wong
    18,200
    6,479
    How do you know the 12V battery is fine?
    Did you check the inverter coolant pump to see if it is running when the Prius is IG-ON? Sometimes when the pump fails, the AM2 fuse will blow, and in those instances the car will not operate.
    49,712
    how many miles on her?
  4. Dvizzy
    46
    Alabama
    Four Touring
    You are the man! The AM2 fuse was blown and replaced fuse and water pump.
    Car is back on the road!
    valde3 likes this.
