Prius Power!
Discussion in 'Gen 3 Prius Main Forum' started by El Dobro, Jan 19, 2014.
  1. El Dobro
    El Dobro A Member
    6,979
    3,214
    Well, it's Prius to the rescue. There's no power in the neighborhood again, so I have my power inverter hooked up to the 12V battery to keep the food refrigerated. Yea! :D
    GrumpyCabbie likes this.
  2. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    EL
    how power your power inverter? I am interested to do it.
    V/r
    Khoi Nguyen
  3. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    What size inverter do you have El Dobro? H
  4. El Dobro
    El Dobro A Member
    6,979
    3,214
  5. El Dobro
    El Dobro A Member
    6,979
    3,214
    It's 1500W, but it never goes that high.
    HaroldW likes this.
  6. HaroldW
    716
    95
  7. bisco
    49,504
    well done!(y)
  8. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    I hope you lock your Prius when it's in READY mode and you are not with it.
  9. mediahound
    903
    155
    BTW - here's a video I did on how you can get totally portable power (without a Prius) using an inverter and portable jump starter. Not nearly as much power as the Prius can provide, but plenty for small items like a lamp, radio, laptop / iphone charger, etc. :
    HaroldW likes this.
  10. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Can you lock it from the outside when in ready mode?
    I recall trying to do that on a recent "0"F morning where I went outside and started the PIP (went to ready mode then put defroster on at 68F which caused the ICE to instantly start up) and IIRC I was unable to lock it using the fob from outside the car while it was in ready mode...
  11. mrbigh
    3,686
    699
    Long Island, NY
    I faced the same inconvenience not to long ago.....
  12. mediahound
    903
    155
    I haven't tried it yet, but can you manually press lock on the inside of the door and then close the door?
    Or does that not work?
  13. El Dobro
    El Dobro A Member
    6,979
    3,214
    If you try to manually lock the doors, they will still unlock.
  14. El Dobro
    El Dobro A Member
    6,979
    3,214
    What I may try next time is to leave one of the fobs in the car and then try to lock it.
  15. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    You have to lock it with the mechanical key - that's what I did when I had my C in Ready for 54 hours straight, powering my house after Sandy in 2012.
    hybridbear likes this.
  16. mrbigh
    3,686
    699
    Long Island, NY
    Agree, I tried the same situation, the hard key......
  17. mediahound
    903
    155
    Interesting. How many gallons of gas did it use that situation? Just curious.
  18. DadofHedgehog
    DadofHedgehog Active Member
    681
    281
    northern Virginia
    MEDIAHOUND, there are a lot of threads on this here. Try searching "using PiP as a generator".
  19. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Less than two gallons, but I was only running a very small inverter to bring up my steam heat, a couple of lights, and the internet. I can't post a link from here but if you search posts under my user name in November 2012 there's a detailed write up.
  20. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Yep! Just use the mechanical(emergency) key
