Prius Prime 2017 12v Battery OEM
Discussion in 'Prime Main Forum (2017-2022)' started by Friendlyx, May 11, 2022.
  1. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    Hey everyone! Does anyone know what the item number for the OEM 12v battery is? Mine is dying and I've done the overnight charge and still dying. I'm hoping to get the OEM one from Toyota dealer and install it myself.
  2. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    I don't think you can buy a real OEM battery that came with your PP made by GS Yuasa that is made in Japan, but Toyota USA sells a replacement TrueStart version of the battery. There have been reports by various posters that this battery is in low availability in many locations. You may not find it at your local dealers. Some dealers do not ship wet batteries, and even if they do, it will cost more to ship and you are not getting the core credit back.
    Part Number: 00544H4052470
    TOYOTA PARTS ONLINE site:
    https://parts.toyota.com/p/69476736/00544H4052470.html
    and a few examples of online dealer sites:
    https://parts.lakelandtoyota.com/p/TOYOTA__/Battery-TRUESTART-H4-EN/14758720/00544H4052470.html
    https://parts.venicetoyota.com/p/Toyota__/Battery-TRUESTART-H4-EN/70043545/00544H4052470.html
    You might have a better chance of finding an aftermarket battery either at local shops or online.
    Here is a list found in this thread:Prime 2019 dead battery | PriusChat
    Flooded:
    - Super Start Premium Battery Group Size 140R H4 (Made in Austria)
    - Super Start Extreme Battery Group Size 140R H4/LN1 (Made in Austria)
    also NAPA BAT75140R (which looks identical to the O'Reilly battery)
    https://www.napaonline.com/en/p/BAT75140R?impressionRank=1
    AGM:
    - ACDelco Battery Group Size LN1 (Made in Germany)
    Still, it is not a very popular size battery, and you may find it difficult to source it. Good luck.
    #2 Salamander_King, May 11, 2022
    BChoAss likes this.
  3. alinica2001
    alinica2001 Member
    94
    38
    Romania
    Mine died today too :) ... I have a 2017 like you have. I will replace it with a standard battery ( probably this VARTA )
  4. BiomedO1
    BiomedO1 Senior Member
    1,446
    790
    SacTown, Ca
    Did you check the electrolyte levels within the battery? Top-off with distilled water; slightly above the plates and try recharging again.
    Hope this saves you from buying a new battery.
  5. alinica2001
    alinica2001 Member
    94
    38
    Romania
    I've already checked that. Levels are ok. I've got signs of a weak battery since a while .... After 5 years it's just time for a new battery.
  6. Marine Ray
    Marine Ray Senior Member
    1,139
    941
    Sparks, NV
    BChoAss and FuelMiser like this.
  7. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    Definitely have been saved over 6 times with it now I just don't want it to one day not boot up we'll see how battery hunting goes.
    Marine Ray likes this.
  8. Mendel Leisk
    38,660
    Phone the parts department, verify they've got the appropriate battery? Not sure why you need to go in armed with a part number; that's their bread-and-butter. Or should be.
  9. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    I called one dealership near me (got a Prius 2006 with them) and decided to give them a call. They said they had 15 in stock. Will be going on Friday, in case anyone is wondering it's the dealership in Lodi,CA
  10. eatriceyo
    eatriceyo Member
    45
    32
    Honolulu
    i purchased my battery from the dealership and got a $10 gift card from autozone for the core. better than nothing
    bisco and BChoAss like this.
  11. mistermojorizin
    mistermojorizin Active Member
    310
    136
    usa
    2019 Prius Prime
    Dealership won't ship them because they're hazardous. I ordered one from a dealer 30 mins away, the site let me go through with the order and offered me frees hipping. Then unilaterally cancelled my order.
  12. Shaunius
    Shaunius Junior Member
    91
    24
    City of Angeles
    What are the chances my 2020 just failed also
  13. Shaunius
    91
    24
    City of Angeles
    Definately get a bigger battery would not recommend stock one at all
  14. PT Guy
    PT Guy Senior Member
    1,085
    710
    Washington, the state
    Failing and discharging are different things. If it won't hold a charge, that's failed. If it is run down but does hold a recharge, it's still good after the recharge. The 2020 battery is probably fine. Our 2017 battery continues to work well. Probably before next winter I'll put the ACDelco AGM battery in just to be safe. (If any age battery became discharged and froze in cold winter weather, it would be junk. But, not in an L.A. winter.)
  15. Gokhan
    Gokhan Senior Member
    4,619
    1,857
    Paramount CA
    The OEM GS Yuasa LN1 battery is not sold as far as I know. Toyota sells the TrueStart H4 Toyota aftermarket battery.
    I would recommend the ACDelco AGM LN1 battery over the aftermarket Toyota TrueStart H4 and the OEM Yuasa LN1. It has a higher Ah/RC rating, and it is AGM instead of flooded-cell. You can order it online for cheap:
    ACDelco 88866037—ACDelco Gold automotive AGM batteries | Summit Racing
  16. Marine Ray
    1,139
    941
    Sparks, NV
    Thx for the tip. Looks like the ACDelco has a 36 month warranty vs 84 month on Toyota OEM. In my 50 years of driving, the warranty experation period is usually when the battery starts to fail.
    Gokhan likes this.
  17. Gokhan
    4,619
    1,857
    Paramount CA
    You cannot buy a Toyota OEM battery. Toyota only sells Toyota TrueStart aftermarket batteries. They are not the same batteries that come with the vehicle from the factory.
    In that case, ACDelco AGM has a 50% longer life than the Toyota TrueStart flooded-cell. The free-replacement warranty period on the Toyota TrueStart is 24 months as opposed to 36 months on the ACDelco AGM. After 24 months, TrueStart has a 60-month two-tiered prorated replacement plan that zeroes out at 24 + 60 = 84 months after the purchase. See the link by @Salamander_King in Post # 2 for details.
    #17 Gokhan, May 26, 2022
  18. PT Guy
    1,085
    710
    Lead acid batteries are very expensive to ship due to the weight. Flooded batteries would need to be shipped dry and the acid electrolyte added at the destination. Expect almost every aftermarket flooded lead acid battery (the common type in most of our cars) to be made in the U.S. There are 3 main U.S. makers--Clarios (formerly Johnson Controls), Exide, and DEKA/East Penn. From the photo I saw of the Toyota TrueStart battery it looks like the distinctive cell caps of Clarios.
    #18 PT Guy, May 27, 2022
    Gokhan likes this.
  19. Gokhan
    4,619
    1,857
    Paramount CA
    I'm sure you're right that Toyota TrueStart is made by Johnson Controls/Clarios.
    Flooded-cell batteries are a mature technology with minimal quality difference between brands. AGM batteries are definitely better than flooded-cell batteries on the average, but the quality probably varies more due to the technology being relatively newer.
  20. Gokhan
    4,619
    1,857
    Paramount CA
    Looking at Consumer Reports ratings, some AGM batteries are very poorly rated while some excel.
    Moreover, flooded-cell batteries seem to have a longer cycle life than AGM batteries. This is probably especially the case if you annually check and top off the electrolyte level.
    So, perhaps, stick with a flooded-cell. Nevertheless, I doubt you would go wrong with the ACDelco AGM LN1 either.
