Prius Prime 2017 Right Headlight Always ON
Discussion in 'Prime Technical Discussion' started by 815kas, Aug 27, 2020.
  1. 815kas
    815kas New Member
    Georgia
    Hello,
    I changed the right headlight on my car and when I click on start engine, the changed headlight is lighting always and does not disappear, does not react at all, just lighting.
    How can I found where is problem ?
  2. Salamander_King
    Salamander_King Senior Member
    10,975
    8,873
    New England
    Did you change the headlight yourself or had it changed by a shop? It does sound like some wire connection error. If you had a shop work on it, I would take back and have it fixed. If you DIY'd it, then I guess, the best bet would be to recheck the connection, but I don't know for sure how hard it is to change the headlight on PRIME.
