Prius Prime 2018 beeping question
Discussion in 'Prime Main Forum (2017-2022)' started by Elfmom, Dec 13, 2022.
  1. Elfmom
    Elfmom New Member
    2018 Prius Prime
    My first time on here.
    I have a Prius Prime Plug in 2018. The strangest thing is happening to me. I park my car in my garage, and it starts beeping about every minute or two. I go shopping and park my car and it's not beeping. I go home and park in my garage and it starts beeping again. I took it to Toyota, for them to check on it. While waiting for some help my car was just sitting there and not beeping, so I took it home again. I'm completely frustrated.
  2. Elfmom
    Elfmom New Member
    2018 Prius Prime
    By the way, the beeping sound comes from the outside of the car. I can barley hear it inside of the car.
  3. BiomedO1
    BiomedO1 Senior Member
    1,474
    796
    SacTown, Ca
    I'm just spit-ball here; because there isn't enough information to make a diagnosis.
    Is the car plugged-in when this happens or unplugged?
    Is that car new to you or did you buy it new?
    Previous accidents; history of the car.
    I'm just guessing the previous owner/dealer installed some sort of anti-thief or tracking device that's malfunctioning.
    Hope this helps.
  4. Elfmom
    Elfmom New Member
    2018 Prius Prime
    I bought the car new.
    It doesn't matter if it is plugged in or not, it will still beep.
    It will only beep in my garage or my driveway. I was wondering if there could be anything near my car that would make it beep. The beeping is not a fast beeping it's slow like every 1-2 minutes.
    No accidents.
  5. Elfmom
    Elfmom New Member
    2018 Prius Prime
    so it's just one beep every 1-2 minutes!
  6. BiomedO1
    1,474
    796
    SacTown, Ca
    Another dumb question; are you sure the beep is coming from your car - not something buried in your garage somewhere?
    I have a jump-pack that beeps about every minute; when the battery is low. The first time this happened; I must've looped through the house, garage, side and back yards about a half dozen times - searching for the beep. I finally noticed a very weak red led flash on my automotive shelf and put two and two together.
    Hope this helps.
  7. Elfmom
    Elfmom New Member
    2018 Prius Prime
    Biomed01,
    Thank you so very much. I never thought of that. My car is parked right under the garage door opener motor. The beeping definitely came from it. ;-)
    BiomedO1 likes this.
  8. BiomedO1
    1,474
    796
    SacTown, Ca
    Glad you were able to figure it out.....
