Prius Prime - 5.6 miles/kWh and 30 miles of EV
Discussion in 'Prime Main Forum (2017-2022)' started by john1701a, Sep 21, 2022.
  1. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    When you own a plug-in hybrid, range of electric-only driving is the focus. But after 5.5 years of owning 2, attention has shifted to EV efficiency. We will be replacing one of our Prius Prime with a bZ4X. That's why I created this video to draw attention to how electricity consumption is measured.
    In this example, it is the same route in the same conditions I have been filming for years to document battery degradation. Turns out, after 5.5 years and 60,000 miles, the outcome is the same. It is still delivering a little over 30 miles. What that means in terms of EV efficiency is a result of 5.6 miles/kWh.
    Watch the video to see detail of the drive. Note that this was 2 complete round trips of 15 miles each. Also note that the screen in the lower-left is an aftermarket app called "Hybrid Assistant" which shows information the dashboard display (lower-right) does not provide, such as true state-of-charge and kilowatt-draw.
  2. GregersonIT
    GregersonIT Member
    172
    92
    Livermore
    2020 Prius Prime
    After 130k I'm only getting about 22-25 miles. But I'm using the defender tires.
  3. Marine Ray
    Marine Ray Senior Member
    1,139
    941
    Sparks, NV
    As usual, great video and info. What tires and tire pressure?
  4. john1701a
    12,755
    5,245
    57
    This was my check from late August.
    Marine Ray likes this.
