Prius Prime auto lock on reverse gear
Discussion in 'Prime Main Forum (2017-2022)' started by Tomca, Oct 21, 2024.
  1. Tomca
    Tomca Junior Member
    47
    CA
    Hi all,
    My prius prime automatically locks the door when I put it to R all of sudden. What might triggered the new change? And how do I cancel that. Only thing I could think of is I fueled my tank today.
    The problem is it takes a few seconds for the car to lock all the door before the rear camera comes on, which is very werid to me.
    Thanks.
  2. BiomedO1
    BiomedO1 Senior Member
    2,769
    1,471
    SacTown, Ca
    Check the condition of your 12vdc battery. It seems that the base settings of your configuration has changed all by itself. That's usually indicative of borderline voltage in your electrical system or someone actually changed the configuration.
    If I recall correctly; auto-lock can be toggled Off or On - (When placed in gear or exceed 3 mph). Sounds like it's currently set On & when placed in gear. The only way to fix that is to reconfigure it to what you want.
    Hope this helps....
    Tomca likes this.
